Question about Radio Shack Cinego D-1000 Multimedia Projector
Cinego projector not reading VGA cable
My cinego projector stopped reading my VGA cable on my laptop this past Saturday. I tried to use the remote pad to reset the laptop Sunday night for over an hour, but the projector kept defaulting back to the DVD status. the projector does work as a DVD player but I use the projector with my laptop for a powerpoint presentation to teach my Driver's education course in the high schools. I need to get this problem solved ASAP.
HELP!!!!
  • 53 Answers
Grrrrrr
Posted on Apr 26, 2008
6ya staff
SOURCE:
Dvd player not working
try to clean the eye inside dvd player and then tern on side
Jul 06, 2009 | Radio Shack Cinego D-1000 Multimedia...
Connect Cinego to MacBookPro
The projector has a computer video cable input on the side of the unit. If yor MacBook has a female VGA output, simply purchase a VGA cable (double male) at a Radio Shack or WalMart, or other comparable retailer, and connect the two. The Cinego will find the input signal from the Mac, and you have to press the right keys on the Mac keyboard to tell it to put the screen signal through the VGA output on the side of the MacBook.
Apr 19, 2009 | Radio Shack Cinego D-1000 Multimedia...
Connecting cinego projector to hp laptop
don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
Jul 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Remote control replacement
http://remotes.com/store/cinego/d1000.html - You can purchase a new remote here. You can get a replacement just like the one you had or you can get a (GENERIC) remote for a little cheaper.
Mar 26, 2008 | Radio Shack Cinego D-1000 Multimedia...
SRC button on cinego projector will not read source
Three (3) things you can try:
1. Lower down the Screen resolution of your laptop as well as the Color quality and the Screen refresh rate before doing the Fn + F5. If it works, adjust thereafter;
2. Do a soft (Factory) reset of your Cinego in the in the Management Menu (credit to Cooljazz); and/or
3. it is just "slow" in sensing the presence of a VGA source as it cycles in its selection, internal DVD, VGA, Composite Video IN. Since it does not have a manual source selection, your only option is to really wait or ...Verify that "Auto Source Select" is enabled in the Management Menu (buttons-Proj/Setup then >/9) and "tap" the "SRC" button on the projector itself to manually initiate the input/source selection.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego D-1000
I have the same problem with my cinego.
Maybe we should all sue Radio Shack to take these machine back
This problem is wide enough to issue a recall.
Dec 24, 2007 | Radio Shack Cinego D-1000 Multimedia...
Cinego Projector to a laptop
Describe the connections available to you on the projector.
Jul 17, 2007 | Radio Shack Cinego D-1000 Multimedia...
I have problem wiht Cinego D-1000
While it is frozen on that "Searching" screen, hold the SRC button down on the actual projector for an extended time. Then after letting it up, hit it briefly one or two times until it finds a source. Make sure that under Projector Setup/Management/ "Auto Source Select" is checked. This brought my Cinego back from the dead.
Jan 08, 2007 | Radio Shack Cinego D-1000 Multimedia...
256 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Pie-man
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
