Question about HP Photosmart C3180 All-In-One InkJet Printer
Check pager jam
I am having trouble with resetting the page jam light. no paper has ever been stuck. the light flashes and I cannot seem to "reset" it. I printed about a week ago with no problem and tryied just resently and will not print. I grabbed a few sheets of paper and tryied to move them all through.
Thanks for anything
  • 2,351 Answers
Two thing you can try. One follow the instruction on the link below. You'll need to scroll down the page till you find the correct light flashes for your reset.
When you do open the rear clean-out door take a few minutes and wipe the rollers off with a lint free water dampened cloth.
If the above does not clear your trouble, click the link below & download the latest driver software.
You can return to the same link & let Hp Automatically check to see if the latest driver is installed correctly.
Hope this helps!
Posted on Jan 23, 2008
Paer prints half the PAGER AND THEN JAMS ... I
The paper must be hitting something to cause it to jam. Take the drum/toner cart out also the paper tray. Unplug it and hold it upside down and see if something shakes out. Do not do this over carpet. If that does not do try a test page. look at the leading edge for dings and bends. If you find a bent spot on the leading edge thats where the problem is. Its almost always a small piece of paper Steven 818-888-0006
Mar 08, 2010 | Dell 1710n Laser Printer
I removed a paper jam. red light is still on (not flashing).
There is probably still paper stuck in the paper path, this is very common. What happens if you load it with paper and press the test button?
Feb 08, 2010 | Samsung ML 2010 Laser Printer
All the lights started flashing after fixed a paper jam
you have take out zamed paper from the printer from the back side of the printer by ejecting the try from back side if it present. or pull out your tonner and then pull out the zame paper.
Aug 22, 2009 | Digital Products Brother HL-2040 Laser...
Paper Jam
It sounds like during one of these jams, a piece of paper was probably left over in there and maybe stuck "out of sight" in the paper path causing the paper to pulled to one side.  Look closely, my guess is that it is only a small corner of a page that is stuck in the path.
Mar 29, 2009 | Lexmark X1270 All-In-One InkJet Printer
202 paper jam
I have this problem too, but the 2 sensors on the fuser are not stuck and seem ok to me. Any other suggestions?
Mar 06, 2009 | Lexmark T632 Laser Printer
Paper Jam error - red light flashing, but no paper jam!
There may be some tiny shard of paper stuck in some inaccessible part of your printer. Examination with a bright light source may help you find it.
Sep 17, 2017 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Brother HL-2070N red "paper" light flashes after a paper jam
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Dec 16, 2008 | HP LaserJet 2200D Printer
Flashing paper light after clearance
moz-screenshot-6.jpglet me see i think when you clean the jam you maybe damage the sensor arm or the arm stuck check the sensor carefully also check the front cover switch
Apr 02, 2008 | Brother HL-2040 Laser Printer
Paper Jams
most likely there is paper or something stuck in that corner
use a flash-light an carefully inspect the area
hope this helps
thanks for rating
Jan 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
189 people viewed this question
Ben Johnson
