Question about ASUS VIA KT133 Chipset A7V133 Motherboard
Display driver for asus via kt133 motherboard
I want display driver for asus via kt133 motherboard
I want vga drivers
Posted on Dec 16, 2008
    Master:
  • 788 Answers
That motherboard does not have on-board video. You definitely have an add-on video card, either in a PCI slot or the AGP slot. Find the model for that one and I can try to find a driver for it.
Posted on Jan 14, 2008
6ya staff
SOURCE:
How many slots for dram chipsets? For AZ11/ AZ31 motherboard? Thanks!
FIC AZ11 (First International Computer {Inc}
3 Ram Memory slots.
Supports SDR Sdram at 100MegaHertz, or 133MHz. (PC100, and PC133 respectively)
Maximum Total Amount is 1.5GB
Maximum Amount for EACH ram memory slot is 512MB. (1/2GB.)
Uses the VIA KT133 motherboard chipset,
(Northbridge - VIA VT8363
Southbridge - VIA VT82C686A/B)
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
Socket A processor socket for AMD processors. (Also referred to as Socket 462)
http://www.xbitlabs.com/articles/mainboards/display/fic-az11.html#
FIC AZ31
3 Ram Memory slots
Same type of ram memory as above, same total amount, and amount for each ram memory slot.
Uses the VIA KT133A motherboard chipset.
(Northbridge - VT8363A
Southbridge - VT82C686B
Socket A processor socket.
http://en.wikipedia.org/wiki/Socket_A
http://www.baber.com/baber/411/fic_az31.htm
Oct 30, 2010 | FIC AZ 11E Motherboard
How can i get vga driver for asus a8v-vm motherboard
Go to asus.com and go to support and downloads driver and select appropriate modelnumber of your laptop and windows version and download it its simple
Apr 18, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Sir i have lose my computer sound driver and video display 2001 model Amd athlone processor Asus motherboard via chip
Thats a Utility Driver. Try this one. Go to Asus website(yahoo search for ASUS.com). Once your in the Asus website,then type in your cpu model or motherboard model in the search box. (for example:2001 model Amd athlone processor Asus motherboard via chip). Then download the driver.
Dec 01, 2008 | Computers & Internet
ASUS VIA KT133 Chipset A7V133-M IDE drivers
Must install motherboard drivers right after you install XP ( chipset is always needed first ) If you use Nvidia drivers or a 4 in 1 make sure you do those first before anything else .
Aug 07, 2008 | ASUS VIA KT133 Chipset A7V133 Motherboard
Upgrading processor to Duron 1.4GHz
well older mother board cant handle a higher CPU processor, you have to make sure you have ALL the jumper properly set for the CPU, also the memory on the motherboard should be for that motherboard. try not to OC the motherboard as it will fry it.
Also check the motherboard for any Blown capacitor. for the MB to scream bloody murder something is definately wrong.
you could check the website of asus and look under ARCHIVE or DISCONTINUED motherboard. to find drivers and manuals for the motherboard you have unless you have them
also make sure the motherboard can actully take a higher processor.
Thermal grease is always good its help alot, just dont over do the grease applications. as ive seen pasta made out of thermal grease cpu's
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 04, 2008 | ASUS VIA KT133A Chipset A7V133-C...
Pc will not boot
try looking for CMOS jumpers of mother board
you see it near the battery of the mother board CLRTC
here the link for the manual
http://www.nek.uu.se/StaffPages/CV/CV93.pdf
Page 14
Jun 04, 2008 | ASUS VIA KT133 Chipset A7V133 Motherboard
Display drivers
Ohh.. Sure !!
the driver its from VIA
u can downlod it from
http://dlsvr01.asus.com/pub/ASUS/misc/vga/km400/km400_window_035.zip
Mar 09, 2008 | ASUS A7V8X-MX SE Motherboard
When i turn on there is display
Probably power supply or motherboard. Too old to fix really, you might get away with a powersupply but it's hard to tell.
Jan 14, 2008 | ASUS VIA KT133 Chipset A7V133 Motherboard
No signal on moniter
are you using an add-on video card? If so, then go to BIOS and enable it.
ASUS VIA KT133
Your motherboard does NOT support SATA drives, without an added SATA controller. It does support PATA drives, such as the Samsung SP2514N and the Seagate PATA drive you listed, as well as any other PATA drive. A PATA drive may be referred to as PATA, IDE, ATA100, ATA133, or even ATA66, but not SCSI, Ultra320, U320, or SATA, SATA II, SATA100, SATA300, etc.
The Seagate drives are easy to identify, their model number ends in AS if it is a SATA drive, and just A if it is a PATA drive.
Dec 05, 2007 | ASUS VIA KT133 Chipset A7V133 Motherboard
Open Questions:
See all ASUS VIA KT133 Chipset A7V133 Motherboard Questions
ASUS VIA KT133 Chipset A7V133 Motherboard Logo
221 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
