My yahoo messenger disappears every time i sign in , i uninstalled and then re-installed but it still does working.
There is a virus. Try installing an antivirus.. or try this, run Command Prompt, Start>Run : type "CMD" without the quotes then type "cd\" then enter to go to the root drive. then, delete the virus by typing "del kxvo.exe /a /s /f" then enter. delete the autorun file as well "del autorun.inf /a /s /f" try signing in after you delete the file. Hope this helps.
I'm having this exact problem. i all of a sudden cannot log into yahoo messenger. i have tried uninstalling it various times and reinstalling 3 different versions. none of this was successful. the log-in window appears when i click the YM icon but it immediately goes off the screen once i try to log-in. please help!
I think this prob occurs when there is no java in the pc
so download the latest java the quick google search will take you there
i am not sure about this
Ihave formated my system three tymes installed yahoo messenger only from net. whenever i type my id &pass word &enterfor login,compleet messenger disappering .give me solution please
surya
Are you using the latest YM? why not try downloading the latest YM but before installing it, uninstall some unwanted programs or those that you dont use anymore...free some disk space.
then try installing the latest YM now.
hope this helps.
First try sign off and sign in for few times , if you still face the problem then uninstall the yahoo messenger and reinstall
Even i also faced the same problem , For few times sign off and sign in had worked or even restarting the PC also worked.
But after uninstalling and installing the yahoo messenger i got rid of the problem
If uninstalling and installing the yahoo messenger also not work then follow the below two steps
STEP -1
go to Start Button - Run - type regsvr32 jscript.dll - then press OK
STEP-2
go to Start Button - Run - type regsvr32 vbscript.dll - then press OK
now your yahoo messenger will work normally.
goodluck
yahoo messenger not at all connecting , please fix it for god sake
whenever i insert my yahoo id and password , and when i hit the enter yahoo is closed and i return to windows...
as i login in to my Yahoo messenger the after typing the password the window dissapears.
as soon as i enter the user id and pass word the window just diappaears i tried to uninstall and reinstall but the sam ething happens
my yahoo messenger disappears every time i sign in , i uninstalled and then re-installed but it still does working.i formated my laptop but even then its not working............
yahoo messenger not signing in
Same Yahoo messenger window disappear when I sign in. Please help fixing
yahoo messenger is not signing every time trying ti isgn in its disappearing allready reinstalled 3 times ,no effect
Every time I attempt to sign in at yahoo! messenger - I got a message, there was a problem signing into yahoo! messenger, please try again a little bit later.
messenger is not signing in i have uploaded, ininstalled, reinstall bt still its not signing in............. plz help me out........ as soon as possible
when i signed in yahoo messenger (beta 8.1), it disappeared immediately. i uninstall it and then install, but i does not work
every time i signed in the messenger dissapear, if im pointing the cursor to the messenger icon below it will also dissapear. i uninstall it and did install again but the problem goes the same.
I been tried to signing yahoo messenger but it's not appear and it automactic log-off and shutdown. Then I been tried to uninstall and reinstall the yahoo messenger and it still the same situation.
i cannot open my yahoo messenger! it dissapears after i sign in, help.
Yahoo Messenger is disappearing once I login with my ID and Password. I have tried to right click on the icon to show the messenger. But it does not work. I have got my PC formatted for getting this problem cleared. Still it is not workable.
dear sir, this has in reference to login problem in yahoo messenger. everytime i used signin the messenger is hang and dissappear. my yahoo id is [email protected]. you are requested to kindly do the needful in the matter immediately
hi
i am trying to download yahoo messenger but it's go from
my sytem what is the problem in my system
I have the same problem my yahoo messenger disappears when I sign in
hi , when ever i sign in to yahoo after putting in my id it just disappears, i tried downloading a different version same thing i need help.
well whenever i sign into messenger itll be on for about 3 mins maybe then itll kick its self off and then itll open again and do the same thing again. and i have uninstalled and re installed it about 4 or 5 times and it doesnt work still.
i installed yahoo messenger it is not working though i uninstalled and re installed there is no use . once i sign it disappears off
as i login in to my Yahoo messenger the after typing the ... insert my yahoo id and password , and when i hit the enter yahoo is closed
