Noise and movement when spinning
Hi there, Just installed the machine and was operating it for the first time. When it began spinning it lurched violently and continued to make a clattering noise and moving forward out of it's space in the kitchen.
Is this something I could fix myself?
Thanks, Alan S.
  • 5,911 Answers
If this is your first time using the machine you may have inadvertently left the shipping bolts installed. The symptoms you described are indicative to a few trouble calls I have experienced with the violent shaking, vibration and movement of a washer having the shipping bolts left in them. Most washers have them installed to prevent the drum from banging around during transport. Most washers have them installed somewhere along the back of the unit. Some washers, however, have a shipping pin installed in the bottom. It is hard for me to determine without knowing the make and model of the washer. Refer to your owners manual to see if this may be the case. If you have only attempted to use the machine once, you should have not any issues to worry about. Prolonged use, however will cause damage to the washer and may not be covered under a warranty or service plan.
Another cause could be improper leveling of the washer. The unit should read level front-to-back and side-to-side. Most leveling problems are easily corrected by the simple adjustment of the feet. Again, refer to your owner's manual and it should give you guidance under the Installation section.
I hope this information may be helpful to you. If you have any further comments or questions, please post back and I will hopefully be able to lead you in the right direction.
Posted on Jan 14, 2008
Another non electrical issue may be how you load the machine or even what you have loaded it with!
Some fabrics hold water and are very dense as a result. These have to be flung out by centrifugal forces to be stuck against the inside of the drum.
Obviously it is going to take a little time for the spinning force to act on a stationary heavy object so there tends to be some violent agitation of the contents before the centrifugal forces take over.
Even if you have removed your transit bolts then this can happen on small loads. If it is still happening I suggest waiting to make sure you have a full load of washing where the agitation is minimised or cut out completely.
Regards
Why is the drum not spinning on my Hoover VisionTech VTS712D21 Washing Machine?
It could be the drum bearings are seizing or something is causing it to jam.
If this is the case the motor would work too hard and draw too much current and consequently would cut out for a time and then reset.
Removing the drivebelt and turning the drum by hand would show if this is probable.
Feb 20, 2017 | Hoover Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
My washer began leaking last week each time I use it. I have checked all the connections, made sure all lines in and out are free from debris. Any suggestions? It sounds to me like the machine is louder so...
Hi just read your posting.Try this on your machine.Power up the machine then advance the cycle to spin.Now push the start button.Does the noise start as soon as you push the start button or when the machine turns the bowl for the spin?Is the noise a rumbling noise or high pitched squeal?If the noise starts as soon as you push the start button the fault is your pump.If the noise starts when the machine spins the bowl then the problem is with the bearings and seals.Please reply with additional information and I am sure I can help you.Looking forward to your reply.
May 23, 2011 | Fisher and Paykel GWL11 Top Load Washer
On spin cycle there is excessive vibration & movement of the machine. I have removed the cover on the rear and have found a brown powder type substance under both the dampers.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 04, 2010 | Washing Machines
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Electrical clicking, motor lurching sound during spin cycle
its not your unit it your electricity,,you have to many thing on 1 breaker..the unit is asking for power ,,a washing machine needs a breaker of 15 amps by its self..put the unit on a oulet by its self..with no other load
Dec 26, 2008 | Kenmore 15864/15862 Top Load Washer
Tilting to the right, makes noise while spinning
if you just bought and installed it refer back to you installation guide and make sure you removed all your shipping braces other than that id make a service call on it as any thing else you do could void your warranty
Jan 17, 2008 | Maytag Legacy Series Top Load Washer
Noisy spin cycle on washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 11, 2007 | Zanussi FLE1416W Front Load Washer
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
