Heated Seats
This system allows the electrical heating of the front seats on passenger demand.
The components of the system are:
- the seat heating elements located in the seat cushion and backrest.
- the heated seat control switch, located on the seat side trim panel.
- temperature sensors located in the seat cushion heating elements.
- heated seat relay.
Do both front seat heaters not work ? Do you know how to test electrical circuits with voltmeter ?
PINPOINT TEST J: THE HEATED SEAT IS INOPERATIVE
Test Step
Result / Action to Take
J1 CHECK HEATED SEAT SWITCH OPERATION
- Key in ON position.
- Press the heated seat switch on the driver and passenger seats.
- Are both heated seat switch indicators illuminated?
Yes
If both indicators illuminate, Go To Pinpoint Test K . If only one indicator illuminates, GO to J5 .
No
GO to J2 .
J2 CHECK THE HEATED SEAT RELAY CIRCUITS
- Key in OFF position.
- Disconnect: Heated Seat Relay C3250 (located under the driver seat).
- Measure the voltage at heated seat relay C3250-86, circuit 1003 (GY/YE), harness side and ground; and between C3250-30, circuit 566 (DG), harness and ground.
- Are the voltages greater than 10 volts?
Yes
GO to J3 .
No
REPAIR inoperative 1003 (GY/YE) or 566 (DG) circuit. TEST the system for normal operation.
J3 CHECK HEATED SEAT RELAY GROUND CIRCUIT
- Measure the resistance between heated seat relay C3250-85, circuit 57 (BK), harness side and ground.
- Is the resistance less than 5 ohms?
Yes
GO to J4 .
No
REPAIR circuit 57 (BK). TEST the system for normal operation.
J4 CHECK THE HEATED SEAT RELAY
- Install a fused jumper lead between heated seat relay 3250-30, circuit 566 (DG), harness side and heated seat relay C3250-87, circuit 1064 (YE/LB), harness side.
- Do both heated seat indicators illuminate when pressed?
Yes
INSTALL a new heated seat relay. TEST the system for normal operation.
No
REPAIR circuit 1064 (YE/LB) to switches. TEST the system for normal operation.
J5 CHECK INOPERATIVE HEATED SEAT SWITCH INPUT
- Disconnect: Heated Seat Switch C320 (Driver) or C321 (Passenger) for the inoperative heated seat.
- Measure the voltage between heated seat switch C320-2 (driver) or C321-2 (passenger), circuit 1064 (YE/LB), harness side and ground .
- Is the voltage greater than 10 volts?
Yes
GO to J6 .
No
REPAIR circuit 1064 (YE/LB). TEST system for normal operation.
J6 CHECK CIRCUIT 57 (BK) FOR AN OPEN
- Measure the resistance between heated seat switch C320-4 (driver) or C321-4 (passenger), circuit 57 (BK), harness side and ground.
Yes
INSTALL a new heated seat switch. TEST the system for normal operation.
No
It's not that simple , being a fuse . It's probably the relay or the heating element .
PINPOINT TEST K: SEAT DOES NOT HEAT BUT THE HEATED SEAT INDICATOR ILLUMINATES WHEN PRESSED ? Does it ?
Your best bet would be to take to a qualified repair shop .
Do
