Question about Acer Aspire 3610 Notebook
I NEED YOUR HELP
HOW DO YOU REMOVE THE ITEMS ON THE TASKBAR (THAT IS ON THE BOTTON RIGHT HAND CORNER IOF YIUR SCREAN)
  • 175 Answers
MSCONFIG
http://www.netsquirrel.com/msconfig/
The following website has step by step instructions for Vista, XP, 2000, etc…
Posted on Jan 14, 2008
    Master:
  • 788 Answers
The best way is to go in that program's properties and disable it's taskbar icon.
Otherwise do this:
Click Start then Run, type msconfig and press ENTER. On the startup tab is all the programs that run on startup on your computer. Find the one you want to stop and uncheck it, restart and it shouldn't return.
If you can't find it then it may be a Windows taskbar icon, in that case there is a specific way to get rid of each. Let me know if you are still having problems.
Im missing my short cut to my recent documents
Could you tell me What Operating system you have , if its Windows 7, you can
  1. Open Taskbar and Start Menu Properties by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
  2. Click the Start Menu tab. Under Privacy, select the Store and display recently opened items in the Start menu and the taskbar check box, if it isn't already selected.
  3. Click Customize. In the Customize Start Menu dialog box, scroll through the list of options to find the Recent Itemscheck box, select it, click OK, and then click OK again. (To remove Recent Items from the Start menu, clear the Recent Items check box, click OK, and then click OK again.)
Tip
  • To clear the list of items shown in Recent Items, click Start, right-click Recent Items, and then click Clear recent items list.
May 11, 2014 | Computers & Internet
I would like to display the date also at the right bottom corner of my computer. The time is already displayed there.
Which operating system do you have ?
The Window's taskbar organizes open and running programs, provides a quick way to access application shortcuts, and gives easy to access to important computer functions and utilities via the system tray. Most users of Windows center their workflow around the Window's task bar for its convenience and ease of use. With the clock function automatically enabled, users can add the date to their task bar while increasing the space for more application shortcuts.
Add The Date To The Taskbar In Windows XP/Vista Right-click on your Window's taskbar and click "Lock the taskbar" option to remove the check mark next to it and unlock your taskbar. If there is no check mark next to it, do not click it as your taskbar is already unlocked. Move your cursor to the top edge of the Start menu and wait for it to change into a double arrow. Click and hold the left mouse button and drag your mouse upwards until the taskbar physically changes in . When it does, it will add the day and the date under the time. Add The Date To The Taskbar In Windows 7 Right-click on the Window's taskbar and select "Properties" from the resulting menu. Click the check box next to "Use Small Icons" to disable the option. The icons will get slightly larger and the date will appear under the time. Click "Apply" followed by "Ok" to save your changes and exit the window.
Mar 15, 2013 | Dell Computers & Internet
Need date displayed, not just edit it, on the bottom corner of my computer
This is for windows 7,
1 - Right click on the taskbar and select properties
2 - Under the 'Taskbar' tab you'll see the 'Notification area', click the Customize button
3 - Click on "Turn system icons on or off"
4 - The first item should be clock. Select on instead of off.
5 - Click ok.
Its slowing down and i want to reset everything were i could start off fresh
before you reset every thing lets do these steps
In order to optimize your computer performance, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3. Run Disk check.Disk Check program is used to check and clean any errors on your computer and keep it running smoothly.
How to run Disk Check:Click Start, click My Computer.Right-click on C drive, click Properties.Now, click the tab, Tools. In the Error-Checking section, click the Check Now. Also, check both of the check boxes: Automatically fix file system error and scan for and attemp bad recovery of bad sectors.
Now, You will see a message box that says you can schedule the disk check to start the next time you restart your computer. Click Yes. The next time you restart your computer, it will automatically run through a disk check before displaying your login screen. After the disk check finishes, Windows will automatically bring you to your login screen.Note: Check Disk can take more than an hour to check and clean errors on your computer.
4.Defragment Your ComputerTo arrange the files in a sequential manner, it is recommended to defragment the hard drive. Click Start, click My Computer, right-click Local Disk, aclick Properties.Now, the Tools tab, click Defragment Now. Now, Click first hard disk, click Defragment.Note: Disk Defragment may take long time like 30-40 minute to complete.
5.Stop Programs from running at the startup.
As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.
Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner. Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.
In order to remove startup from the registry go the following locations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolder
Right click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.
Restart your computer.
6.Uninstall the useless programs(like gaming softwares, unnecessary toolbars like my web search, myfreeze toolbar)Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
7.Scan the computer with good antimalware, antispyware, antivirus.
http://malwarebytes.org/http://superantispyware.com/
8.Update the drivers on the computer.Click Start, Click Run(Window XP) and type devmgmt.msc(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required).Right click the device, click Properties.Click Driver tab, and click Update Driver.Follow the on screen instructions to complete update.
9.Upgrade RAMWindows can run slow if you do not have enough RAM.Many newer operating systems and programs use more RAM when they are running.How to check RAM.Click Start, right click My Computer, click Properties. You will see the RAM mentioned her.You should have at least 1 Gb(2 GB would be even more better)RAM.
10.Update Windows
Windows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click Automatic Updates tabclick Turn automatic updating on and click install updates.
Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows Update,click Turn automatic updating on and click install updates.
PS Please Note to leave a positive note.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Slow running laptop
10.Update Windows
PS: Please leave a positive comment
Jul 07, 2010 | Dell Inspiron 700m Notebook
How do i get my start button on the left corner of my screen? it is at the top right now.
The Start Button is on one end of the "Taskbar"
Use your mouse to move the cursor anywhere on the task bar, click-and-hold, and drag the taskbar back down to the bottom of the screen.
If it won't move (you try to drag it but it's not going anywhere) then right-click on the task bar and un-check the menu item "Lock the Taskbar" then try again.
If this helps, hit the "thumbs-up" for me.
If not, use "add comment" to ask any questions you might have, then check back for answer from me or another FixYa expert!
Jun 18, 2010 | Computers & Internet
How do i hide my gateway taskbar? used to be hidden and now it needs to go back to bed! so annoying! please help!
Gvie you a screenshot guide manual:
Customizing the Taskbar ub_clear.gif Step 1: Overview ub_clear.gif
ub_clear.gif To set taskbar options, right-click the taskbar and choose Properties to access the Taskbar and Start Menu Properties window. There are several options available. ub_clear.gif ub_clear.gif Step 2: Auto Hide ub_clear.gif
ub_clear.gif Checking the Auto hide box will cause the taskbar to move out of sight when not in use. Then when you move the mouse pointer over the taskbar location, the taskbar will reappear. ub_clear.gif ub_clear.gif Step 3: Always on Top ub_clear.gif
ub_clear.gif Checking the Always on top box will cause the taskbar to be visible even when you have maximized application windows on the screen. ub_clear.gif ub_clear.gif Step 4: Show Clock ub_clear.gif
ub_clear.gif Click the Show clock box to display the clock on the taskbar. It will appear in the bottom right corner of your screen when this option is checked.
Power and Gateway battery life knowledge and tips.
>> orginal from http://support.gateway.com/s/tutorials/Tu_850630.shtml
Jun 02, 2010 | Gateway M305CRV Notebook
Bottons on microwave do not work
HI, the touch pad board has failed. you will need to replace this damaged board asap. this will correct the issue.
Sep 27, 2009 | Microwave Ovens
Xbox
see this web page for your problem on red light
Sep 04, 2008 | Microsoft Xbox 360 Console
Start menu problem
You should be able to drag your start menu around. Try right clicking on it and there should be a pop up menu, one of the choices should be lock task bar uncheck it then you should be able to move the bar back to your liking.
Aug 24, 2007 | Microsoft Windows XP Professional With...
Acer Aspire 3610 Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
