Sansui Dolby Digital/DTS Receiver RZ-6700AV
Hi
I have a Sansui Dolby Digital/DTS Receiver RZ-6700AV.
My problem is that the digital receiver cuts the sound out after about an hour of play time while using either a Fibre Optic cable or Digital cable. If using the 6 channel output it works fine.
It’s like the unit overheats when using the Fibre Optic or Digital cables.
Please let me know what I can do about this.
Thank you
2 Suggested Answers
SOURCE: Sansui
I need a card with SMD ICs located on the circuit board of my sansui RZ6800 AV Reciever.(its a digital card with function IC and many more SMD components)
Posted on Apr 30, 2010
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
What kind of optical or coaxial cable do i need to get exces to dts and dolby digital
To get DTS and Dolby Digital sound you will need one of a few types of digital cable to connect the digital output on a device to a digital decoder or receiver. One type of digital cable is the SPDIF Coaxial, which is a single cable that can transmit high quality digital audio. Another cable for digital sound is the Toslink Optical cable which uses plastic or glass fibres depending on the cost to transmit light which is then decoded into sound information. With optical cables the signal can break if the cables are bent too much. The other cable that can be used is the HDMI cable, this is used to stream HD video and HD sound formats such as DTS HD Master Audio and Dolby True HD, these can of course stream the standard Dolby Digital and DTS signals, but for what it is worth I would recomend a SPDIF Coaxial cable. These can be found at hi-fi shops and places such as Maplins or Ebay. They are also cheaper than the other digital cables and more reliable than optical ones. Any type will do as long as you have a decoder or home receiver which can convert the digital information into sound. Infact you can use an RCA composite cable and connect that into the coaxial ports at either end. This will transmit the digital information, but not as good quality as a proper coaxial cable, but you still get the DTS and Dolby Digital formats with full surround sound. I hope that this helps.
Jan 08, 2010 | Audio Players & Recorders
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Feb 08, 2009 | Onkyo TX-DS696 Receiver
Sony str-de675 cuts out in dts mode
Your optcal line may have a break in it ! try another opt cable or try useing the digital cable out!
Dec 13, 2008 | Sony STR-DE675 Receiver
Display while playing movies
Hi, no, this is not the normal display. It should indicate the digital sound format like DD or DTS, etc. If it is displaying PCM, this is probably due to the audio settings on your DVD player. Please provide your DVD make and model, and I will look to find the solution.
Nov 24, 2008 | Harman Multimedia AVR-354 Receiver
Dolby Digital Has Stopped Working
i sthe thx dobly digtal button on off or on auto ?
Nov 14, 2007 | Kenwood VR-505 Receiver
Sansui
Sep 01, 2007 | Audio Players & Recorders
207 people viewed this question
 Grubhead
Grubhead
