Question about Dayton G73 Utility Heater
Installing a Dayton G73
I'm using 10/3 to wire a G73 unit. I assume the L1 and L2 are the "hot" wires (black and red). The ground (green) goes to the screw on the housing, what about the neutral (white)?
  • jpmach1 Jan 14, 2008
    Thanks
  • 579 Answers
If that is a 240V unit then you are correct wiring L1 and L2 to black and red. Unless the unit uses 120V for something like a control panel, it doesn't need the neutral.
Posted on Jan 14, 2008
I am an electrician by trade, the neutral (left over white) is not necessary.
Posted on Apr 11, 2008
ON A DAYTON 1MBF6 ELECTRIC GEAR MOTOR, WHICH WIRE IS THE L1 AND WHICH WIRE IS L2. NEW IN BOX AND NOT LABELED.
most motors come wired 220 volt from factory if two same color wires or black and color or two colored and green measure between colored should get 220 volt colored or black go to L1 and L2 and green ground if 120 volts see side of motor for wiring then black L1 white L 2 green ground or case if 120 volt must change wires in motor
Oct 19, 2017 | Dayton Pool & Spa
A.O. Smith 1/4 hp 115v red black blue and white
Not sure what wires you are talking about. Normally on a 115volt motor you will have L1 and L2 and a green ground screw. Black or red goes to L1 and L2 (either one). White goes to either L1 or L2 (either one) and the green ground to the green ground screw. These would be the incoming voltage wires.
Sep 13, 2014 | Pool & Spa
I disconnected the pump and need to know where the red black aND WHITE wires go
Hi, this is John the Hayward tech. You say the wire colors are Red, Black and White. Does not seem that the wires colors were correct from the start. Not knowing your voltage let me clarify some things. Normally if you have 115volts coming into the pump you wire colors should be Red or Black to L1 White to L2 and a green ground to the green ground screw. If you have 230volts coming into the pump the two hot leads are normally red and black with a green ground. The red and black wires go to L1 and L2 does not matter red or black. The green goes to the green ground screw.
Sep 03, 2014 | Pool & Spa
I am trying to wire a dayton booster pump. it shows a L1 and L2 connection on the 115v connection. L1 goes to P1 L2 goes to T4. on the 220v connection it shows L1 and L2. L1 goes to wire P1 and L2 goes...
The power cord has a green ground wire; two hot wires, which are black and red; and a white neutral wire. Attach the neutral to the middle connector and the two hot wires to either end of the terminal.
In order to safely ground the machine the green ground wire must be securely connected to the dryer frame. There may be a screw on the frame where you can attach the ground
Jul 17, 2011 | Kitchen Ranges
I take it the wiring harness in front of me is 3 Phase. I have a Green wire, Red, Black and White. The wiring diagram on the back is marked L1, L2, N, E. Just need to know which wire goes where thanks.
It is not 3 phase...just single phase 240V....L1 goes to the one hot side of the 240 v, l2 goes to the other hot side of the 240V, N goes to neutral, and green goes to earth ground (metal box)
so....L1=Black L2=Red N=White E=Green
Jan 22, 2011 | Ovens
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
I have installed a Dayton G73 heater in my garage along with a 240V outlet. I am using a 3 prong dryer cord and I am having difficulty figuring out which wire to hook to L1 and L2. I have determined the...
here's a link to the install guide
www.air-n-water.com/manuals/G73.pdf
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Installation-Dayton-G73-Garage.htm
Nov 02, 2009 | Heating & Cooling
Hooking up my heater
The white is the common neutral, it is probably a 3 wire unit, and you are missing the ground wire. Check inside the control panel and see if someone wired it using the white wire for the ground, it will be screwed into a terminal lug. Check the schematics to see if the unit requires a common neutral to run the controls.
Nov 24, 2008 | Dayton G73 Utility Heater
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Dayton G73 Utility Heater Logo
1,198 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
