-   A few months ago I replaced the IC for convergence problems and all was good. Recently when turning the TV on, there is a pink effect to the whole screen. This will eventually clear up after 20 minutes or so. Additionally, if we leave the TV on, it does not revert to pink. Is this something with the red gun? How can I check it?
Thanks!-   TL5sch
Sounds like your red gun may be shorted, Try adjusting the red gun down a little see it that helps.You can also switch the blur CRT socket for the red if your screen is still mostly pink then you know for sure its your red tube that needs replacement. If its mostly blue then you have a problem in the red drive circuit.
Hi, I bought an Alba CDVB4 and when i use the remote to change the channel on the set top box it...
(More)
Hi, I bought an Alba CDVB4 and when i use the remote to change the channel on the set top box it actually turns the channel over on the tele not the box? Thanks Mark
hi got a humax pvr & panasonic 32" lcd tv (both new )occasionaly the two units do not...
(More)
hi got a humax pvr & panasonic 32" lcd tv (both new )occasionaly the two units do not connect.I select hdmi 1 to watch the pvr &and it seem as the tv does not reconize the pvr.or it there is no info on screenjust like it locks up.has anyone else had this sotrt of problem and is there a cure for it
