Related Tags:
This problem should be removed because:
Problem with Motorola CLIQ Cell Phone
my cliq will not charge..
This is the second time I have tried to charge my motorola cliq..and it shows no sign of charging.
Solutions (4)
Best Solution
I Have the same problem. The Charging indicator is charging but the battery drains instead of charging. I swapped batteries and the same thing happens
Make sure it's not just the battery (swap with battery from friend)Otherwise it could be the usb port logic board, you can try to replace the it yourself:If you can't get a replacement under warranty there is both a T-Mobile Cliq Repair Guide and a third party T-Mobile Repair Service, If you try a self-repair make sure you feel comfortable with opening devices like that.
do you vknow if the charger works at all? what happens if you use the usb cable that came with it and connect it to your computer? if the computer does anything at all when you bplug the cable in then I wsould say you have a faulty charger.i truly doubt changing your battery would solve anything. if it were the batttery you would either see it trying to charge or get a battery error. i really do not think that is the problem.
replace the battery
my cliq does not charge actually seems to
my cliq does not charge actually seems to discharge fasterwhen plugged in
My moto cliq starts to charge but then counts back
My moto cliq starts to charge but then counts back down to charge to zero.
my motorola cliq just turned off and will not turn
my motorola cliq just turned off and will not turn on i tried charging batterey but nothing happens the screen staays blacked out and the...
My motorola cliq. The phone wont light at all
My motorola cliq. The phone wont light at all unless the wall charger is plug. 1.it will vibrate 2.stay on white screen (m) logo for a few...
Add Your Solution
making an account for a motorola cliq
when i sign up for a motoblur account it says the request timed out waiting for a response
Fix-O-Meter
3,622
3,622 people viewed this problem
- 17 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Motorola Cellular Phone Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
