Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Hitachi Rear Projection
The picture on my rear projection Hitachi has turned a red hue through out the screen and the whites are now gray, any ideas? Thanks for any help.
  • hypochris Jan 14, 2008
    I have tried both with no luck. Anything else that I could try?
  • 4,402 Answers
Have you tried magic focus and convergence?
go though this check list:
Posted on Jan 14, 2008
  • Cary Farah
    Cary Farah Jan 14, 2008
    replace convergence amp ic's
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
My hitachi 53udx10b was supposedly just serviced but the picture is extremely blue. Have tried adjusting picture to no avail. Help.
I am going to tell you a simple thing to do to know what your problem may be.
With the set on turn the color all the way to zero. Go to a channel if you can that is in black and white. What color is the screen?
If the answer is that it is blue in the background whoever serviced the set did not and could have removed front speaker grill and inspection plate behind it; there is a black plastic block with three screen controls (red,green,blue) and 3 focus controls (do not touch the focus ones.)
I suspect if the blue screen is there a slight adjustment of the blue screen down will correct this.
The picture with the color at zero should be black and white or gray. If blue is background color it will also be with color.
This is called gray scale; picture with color off has to be gray or black and white.
Before you rate this solution if you have questions make a comment right here and I will advise you.
Jun 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
There's a green hue over everything
One of your other color tubes( blue or red ), is blown. The green saturation you are seeing is beacuse you are missing a color to complete the picture. Rear projection t.v.'s are pretty cheap to fix with this problem. Just contact a t.v. repairman.
Dec 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Yellow hue circle in middle of screen. after leaving tv on all night
spherical or oval shaped light starting in the center of your picture is an indication of an led backlit tv.. probably a hitachi. solution, replace light no garuntees not with led backlit sets.. was bad idea to begin with. when the leds start going they start at the center and branch out.
Apr 13, 2009 | Hitachi 50V715 50" Rear Projection...
Phillips 51" Screen Distortion
See if the issue happens in the menu alsoif not replace the small signalbaord.
Apr 25, 2008 | Philips 51PW9303 51" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Picture problems
Retrace lines on picture, 60V on RGB transistors
C700 (100nF, 250V) seems to be leaky, but main problem is R723 which had gone from 27R to 1.2M, both on CRT board
Nov 24, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
