Manual Can i DOWN LOAD A MAN FOR THE BROTHER T96 FAX/PHONE/
  • Stastny Feb 11, 2008
    Cannon Laser class 7000 - keeps displaying "check printer #330"..in the past if we turn it off...it would work for a day or so and the message will come back...now after turning it off, still display #330...what does that mean? We have no manual. Thank you.
    Scholar:
  • 78 Answers
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
How to disable my fax/tel mode? I can't receive any messages, because the fax keeps coming on after the third ring?
Disable the FAX auto-answer
Press the FAX button
  1. Menu/Set, 0, 1
  2. Use the up/down arrow to select Receive mode to be "Manual"
  3. Press Menu/Set
  4. Press Stop/Exit
Manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057875.pdf
Mar 15, 2011 | Brother MFC 420CN All-In-One InkJet...
When Brother T96 Fax Machine prints, it takes all the paper through the machine at once then the paper gets jammed.
I believe your feed roller needs replacement. First try cleaning it with a 50/50 of water and alcohol solution, sometimes this rollers get sticky because of the dirt and humidity. Clean it and tell me how it work, it is only one feed roller right at the bottom where the paper sits
Aug 03, 2009 | Brother FAX-T96 Plain Paper Thermal...
Cannot receive faxes
the brother I/F 885MC ( MC stands for message center ) it has a built in answering machine.
to use the built in massage center you need to press the receive mode key till the display reeds
( MSG CTR) next to the time & date
the way the fax need's to be hooked up is from the wall jake to the line jake on your fax machine.
anything you need after that you go from the ext. jake to your ansering machine or extra phone.
if you don't have owners manual go to www.brother.com you can down load manual
hope this help
Feb 11, 2009 | Brother IntelliFAX 885MC Plain Paper...
Can't send faxes
First disconnect the fax from the phone line. take regualar phone and plug into the wall outlet. dial thefax number. and listen for the the fax tone.
if the line is good. connected the fax and do the follwoing:
Manual Fax mode:
Press the fax icon (should turn green)
Load the document on the scanner glass.
Dial the fax number
press Mono Start.
if not, try to find a good phone line to use.
Feb 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
Need instruction manual for a brother 560 fax machine
If you go to www.brother,com you can down load owners manuals
Jan 30, 2009 | Brother IntelliFAX 560 Plain Paper Fax
User´s guide
HELL, MY NAME IS STEVE, YOU ARE INTERESTED IN A OP MANUAL FOR THE BROTHER FAX 275 YOU CAN EITHER ORDER IT DIREC FROM BROTHER AT 908-704-1700 OR GO TO BROTHER.COM AND DOWN LOAD IT.
Jan 15, 2009 | Brother Personal FAX-275 Roll paper...
I need to know how to use my fax machine it is a brother personal 275
what is it that you need to know? you should go to brother.com and down load the manual it is free brother tech
Dec 10, 2008 | Brother Personal FAX-275 Roll paper...
103 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
