Question about Cameras
System error My camera comes up with a system error and does not take pictures. The lens does go in and out when top dial turned to scene but stays out when power button turned to off and then displays system error... I have tried removing card and battery ...any ideas apart from trashing it? Tony
  • opsyne Aug 04, 2008
    I think this is similar to what i`m` experiencing as well when it turned to camera itself a message is shown that says(Lens process power off) cant understand that at all. And after taht it went off so by so doing , i cant perform any pther activity on it again. Pls help me out, the lens doesnt come out at all which means i cant take pictures agin, and other relative things. All i can only do is to see the old pictures i took, thats all. pls reply me as soon as possible. Thank you.
Go to your camera settings and reset what you can, especially the date and time. Take the batteries out if they are old and leave them out over night. Then turn it on and see if the message is gone. If not, then you may need to get service for it if it doesn't cost you too much. The above things I did fixed mine. Its a Nikon coolpix 800. I just hope it lasts'.
Posted on Jan 31, 2008
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
My camera will turn on then go off and the lens will not go out how do i fix this?
The manual is a bit confusing. I do have a power shot, but is is a bit younger. My camera does have 2 On buttons. One to put it in shooting mode. And one to set it in display mode. If I press the display button (arrow right) the lens stays where it is and I only can see pictures I took. When I press the on off button the lens comes out.
I think you only have to switch the main dial to the camera logo (shooting Mode) and then press the Disp button, to shoot pictures and if you want to view pictures, you turn the dial to playback Mode (arrow to the right) and press the Disp button.
If it works, no fix, just knowledge about how the camera works. It is all in the manual.
Jan 14, 2014 | Canon PowerShot A520 Digital Camera
System Error (Focus) ...Lumix DMC-FS15 works, pauses, then results in a white error screen with the following error message:
My camera started bringing up "system error (zoom)" and it was completely inoperable. I would turn it off, but the lens wouldn't retract unless I applied slight pressure to it. I was able to FIX this problem by applying some lubricant oil to a Q-tip and swiping it around the telescoping parts of the lens, being very careful to stay away from the actual lens. I turned the camera on and off a few times so the oil could work its way into the parts, and it fixed the problem. I don't know if it will be a long term solution, but I can at least download my pictures to my computer now!
Oct 08, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
The lens comes out then the camera turns off
Your camera has it own doctor built in, if it sees an internal error it will shut down. When a camera turns on it goes through a series of tests, if one of these test fails your camera records an error. If the lens is moving in and out your camera is trying to get the lens to function. As such you have a faulty camera.
Jul 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Nikon 50mm 1.8 lens error message
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Jun 25, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
When the camera is turned on with the power button the lens comes out and stays out but the camera immediately shuts off and the lens stays open. The only time the camera remains on is when the dial at the...
Please try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 13, 2009 | Sony Cameras
System error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 06, 2009 | Sanyo Xacti S650 Digital Camera
Lens Error
Only Nikon can tell you that. Looks like the autofocus lens mechanism broke inside.
Nov 19, 2007 | Nikon Coolpix 8800 Digital Camera
Error message
*&%$@#%^&*&^% !!"It's working!!!! Turn your camera on and put it near your ear. Did you hear a softly motorized sound in the lenses area and the green LED is flashing? If you hear this sound do this. Do it under your own responsability. (any way your camera does not work). When you turn on the camera wait until the lenses come out, in that moment grab the lens with your hand and don't let it go back. The camera will turn off but the lens will stay out. With the camera off push in the lens with your hand. Turn on the camera and that's it. I had to do it 2 times, but now my camera it's working again. This system error could be caused because the lens get out of it rail and the camera can not set the focus system.
Oct 18, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Cameras Logo
357 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
