Question about Sanyo DS27510 27" TV
Problem IC get lick and burn,i could fix it if i get the ic number back because it burn so bad i cant see the number.So if you can help me please let me know,the place on the board where the ic is ,this is the number on the board where it was,1001 and its a Sanyo manufacturing corp-3333 sanyo road  Model # DS27425  family group VB8D , Serial # V5190492614666  ,Chassis #  27425-01 and its a flat screem and between 26'' /27''
    Novelist:
    Champion:
  • 232 Answers
Deko, heres the number for Sanyo parts, 800-877-5032, you can order the service manual there, part number for manual is KTDS27425. I`m sorry I don`t have it to look up the IC but it will be very usefull to have the manual, I think it`s around $20.00
good luck with it, BMW Rider
Posted on Jan 14, 2008
Bose burned Integrated Circuits
I have the same problem here, this IC is shorted, is made by International Rectifier, it must be a inverter IC the number printed should be a ghost number because I can't find it, maybe BOSE ask IR to put a nonexistent number to block people fix it, the number by the way is P834 HA1M1 here is a photo also, if someone knows about which other number works here let me know please
Aug 13, 2013 | Apple Bose SoundDock Series II Digital...
Sony ericsson EP800 USB+5V charger IC SO8 is burned and I can't detect the part number
Just get another on EBAY. It's not worth messing with versus expense. Ya, it probably could be fixed, but hard to find a schematic for it.
Dec 10, 2012 | Sony Ericsson EP800 Power-Saving...
There were lines at top of TV for sometime then today TV just shut off by it self and burning smell was apparent. Tried turning tv back on and just got souns and a bright line through center of TV. My...
you have a vertical problem . You will need the chip or IC. please check the voltage source to the chip(IC). Diode could be short. Ic had bad solder joints and there are 2 caps that will need to be replaced 100uf or 220 uf caps in the vertical circuits.
Nov 04, 2010 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
WS-55819 Mitsubishi Rear projection TV Picture goes blurry
Convergence ICs are bad need to be replaced. You will need to replace both of them also check the resistors right next to the IC often 1 or 2 of them burn out when the IC goes.
Feb 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Philips 17PF8946A/37 burned IC.
That sounds like the vertical sweep IC. Can you see a reference designator for this IC?
Dec 21, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Convergence amp
Heat or not using the right replacement IC if it keeps burning out. If it is the first time it happened, the heat sink compound dries up, and then the heat transfer goes down and the IC overheats. If the IC is burning out a short time after you replace it, you are probably using a cheapo aftermarket type or a factory reject IC. You need to use an original replacement, not just one with the same numbers because all IC's are not alike, even with the same numbers. You also need to put new heat sink compound paste on the back of the new IC's before you replace them.
Sep 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Sanyo DS27510 27" TV Logo
117 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
