Question about Ricoh Aficio AP3800C Laser Printer
Ricoh error code sc291
The printer shows error sc291 also it is recognizing the blue ink anymore the stats shows auto power off due that error
  • 788 Answers
There's a list of Ricoh error codes right here: but it doesn't indicate an sc291 for the 3800 or for any other model for that matter.
There are usually contacts on the cartridge that interface with a reader in the printer to detect the chip in the cartridge. Examine a cartridge and look for any electrical contacts, make sure they don't look damaged or dirty clean them with 98% isopropyl alcohol. With the printer powered off and upplugged, try to find the corresponding contacts inside the printer for each of the contacts on the cartridge, clean those too.
If that doesn't change, try a different cyan cartridge, if that still doesn't work you will probably have to get the machine serviced.
Posted on Jan 14, 2008
Ricoh gx7000 error code 993
This signal is triggered by the HVPS due to an accumulation of
condensation or ink spillage onto the transport belt.
?? Clean the transport belt.
Feb 28, 2014 | Ricoh Corp Aficio GX7000 GelSprinter Print...
Ricoh mpc 6000 sc540 error code
my reecho mpc6000 calur macing problem yellow toner add , pl help
Jan 31, 2013 | Ricoh Aficio Office Equipment & Supplies
My fax printer is flashing with error 5Boo check printer and my computer screen show"the ink absorber is full contact the service center" what need to do???
The ink absorber is basically a sponge that absorbs extra unwanted ink during the print process. When it can no longer hold anymore it shows this error. Replacing this is about the same as changing the ink carts for difficulty. You can find the proper one in your manual near the back under supplies and these can be bought at most stores that stock a good amount of printer supplies. You just open the access panel pull out the old and insert new one. The printer will then recognize it is new and will clear your error.
Jan 16, 2013 | Office Equipment & Supplies
Have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Mar 23, 2009 | Office Equipment & Supplies
Hello, we're getting an error code of 990 on a GX5050n inkjet printer. The printer is fairly new with only a dozen or so printouts. Thanks.
make sure printer is off. Then old down escape and online button at the same time. Continue to hold these two buttons down then turn on printer. Continue to hold those two buttons down (will take about 2 - 3 minutes). This should clear that message - worked for me!!!
Aug 07, 2008 | Ricoh Aficio GX3050N Printer
Ricoh GX3000
ERR (990) or ERR (999) are both error messages which are displayed when a sensor does not work normally due to dirtiness. For example, either may be caused by a dirty maintenance unit or clogged ink nozzles. It may be possible to resolve the issue by cleaning the device
look here for instructions:
Jan 25, 2008 | Ricoh Aficio GX3000 All-In-One Printer
Ricoh ap3800 error code sc261
Hi there the following is taken from the service manual. Thanks J
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
5. Check and/or replace the PSU.
Jan 14, 2008 | Ricoh Aficio AP3800C Laser Printer
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Ricoh Aficio AP3800C Laser Printer Logo
1,015 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
