Question about Acer Aspire 3690-2196 Notebook
Wireless conection I have been given the laptop after it was dropped, tha screen smashed, the hinges broke, and all connecting wires were ripped from the motherboard. No problem, ha, everything works except wireless itrs got to be on top of the router to get a signal. Question. is the wireless antenna in the lid? if so where do the "bare wires" go on the motherboard? yes the connector did not survive.
  • 1br0ke1t Jan 14, 2008
    a MiniPCI card was located with broken wires still attatched thank you to "The Machine" the laptop is an acer aspire 3690.
    now where is my soldering iron.
    Master:
  • 788 Answers
The antenna is in the LCD. The antenna usually connects to a MiniPCI card situated usually next the the memory or under the keyboard. They connect via small coaxial connectors. I've never seen them connect directly to the motherboard an any notebook I've worked on.
Posted on Jan 14, 2008
  • 89 Answers
That depends. What is the make of the LT?
The hinges on my HP laptop are broken and the wire the connects the screen to the laptop is broke
To repair this; you will be broke. Just get a new computer...the cost is too great to obtain the parts necessary for repairs.
Feb 23, 2014 | HP Pavilion dv6000z Notebook
Broken wireless antenna
can buy it from www.direction.com, www.ebay.com, ww.flipkart.com
Jul 26, 2013 | Toshiba Satellite M305-S4826 Laptop
What are the 2 wires that run through the right side hinge?
It's your display wires. They probably got pinched too hard when it broke.
Jun 17, 2012 | Acer Aspire One D255E-13281
How do you fix a dm4 Hinge that is broke where it connects to the screen
You can buy hinges on ebay at:
http://www.ebay.com
Just type your computer make and model in the search followed by lcd hinges.
If the hinges are broken where the lcd screen connects to the base of the laptop then you will have to remove the screws from the bottom of the laptop and remove the strip that is at the top of the keyboard to get to them.
If the hinges on the side of the lcd frame is broken then you will have to remove the plastic strip that is around the lcd screen. Remove the plastic or rubber bumpers on the plastic strip then you will see screws to remove to remove the plastic strip. Then you will see hinges and screws on the side of the lcd screen that you can remove. Once you have them removed you can lean the lcd lid forward so that it drops in your hand. Don't let it drop on the keyboard, just into your hand and not too far because there is a cable on the back of the lcd that you don't want to damage. The cable can be taken loose from from the lcd at the back near the top if you like. Sometimes there might be a piece of tape securing it. If the lcd screen does not come out then there are screws on the 4 corners that is securing it and the hinges.
May 13, 2012 | Computers & Internet
I think there is a loose wire from the laptop hinges to the screen backlight when i open the laptop it only lights at a certain position and have to move the screen back and forth to get the light on
dodgy conection to the screen inverter take off the screen surround 4 poss 6 screws located in each corner of screen and poss 1 behind each hinge in the middle at bottom of screen make sure the pink and white wires are connected properly if not press them in if they are the problem is 1 of 2 things either the inverter is faulty or the pink and white wires are either snapped or not connected to the back of screen or motherboard correctly
Oct 09, 2009 | Computers & Internet
I broke a bunch of the wires on the wiring harness
You need to get yourself a shop manual and rewire the harness in accordance with the wiring diagram in that manual. I bet if you look online you can download it for free like I did.
Oct 02, 2009 | Polaris ATV
Internet connection
try to update the router's firmware to the latest one, if conection is still dropping try lowering the MTU size(by default its set to auto) to 1492, 1480, 1472, 1450 check which MTU size will make you connection stable.
Aug 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
CyberHome CH-LDV 700B Portable DVD Player
you've probably over extended the the flat wirecable that powers the screen inside the dvd player by opening the screen too far. Open the dvd player as if putting in a dvd, now look in the right hand upper corner and you'll see a white flat wire, this wire is probably your problem. open the dvd player and look at the connection, the wire should be crooked, push the wire into the connection securely and the screen should come on. check it out!! Mr.Fixright.
Aug 08, 2007 | Cyberhome CH-LDV 700B Portable DVD Player
Acer Aspire 3690-2196 Notebook Logo
85 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
