Question about Stoves 850DODLM Gas Kitchen Range
Gas stove cookie burning on edge and raw in the middle
Oven turns on byitself
Posted on Mar 03, 2008
Oven burns in back and raw in front
That oven is very poorly rated and is prone to a lot of repairs. Most people advise to get something else. There is no common solution. I am sorry.
Feb 15, 2013 | GE Profile JTP56 Electric Double Oven
What is a liquid gas stove?
A liquid gas stove is a type of stove that uses a fuel tank in order to operate. Liquid gas stoves are capable of burning different types of fuels like alcohol, white gas, automobile gas, and kerosene.
Oct 25, 2012 | Camping, Backpacking & Hiking
When baking the oven doesn't bake evenly and always bakes quicker than the time on recipes. Items burn and the middle is raw. Can the oven be recalculated to work better?? John
Electric ovens are always different from gas ovens. You have to set the temperature on average 10-15 degrees lower and watch out 15 minutes earlier if you are baking cakes, 5 mins for cookies etc. Always bake in the centre of the oven. use a metal bowl of water in another tray which may help balance out the temperature
Jan 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
My baxter rotating tray oven is not baking cookies evenly. The cookies on the outside of the cookie sheet are over-done and the cookies in the middle of the cookie sheet are not done ??
Inside your oven you have an array of louvers or fins in the back left corner and the front right corner. Sometimes a tray will jam and knock one of the louvers out of adjustment. You may need to call a local authorized service provider to come and reset your louvers to the factory settings. In the meantime you can attempt to make small adjustments to see if you can rectify the issue.
Do not ever adjust the louvers in the back left corner of the oven.
For the trays in question, to direct more air towards the center of the cookie sheet slightly bend the louvers in the front right backwards towards the rear of the oven. ONLY MAKE SLIGHT ADJUSTMENTS!! If you bend the louvers too far you will end up burning the center of the cookie sheet and under cooking the edges.
Jun 14, 2010 | Baxter OV300E Stainless Steel Electric...
Oven not cooking evenly.
If the oven door seems heavier than before as well it could be the sign of a weak or broken spring. The door would have to be taken apart(carefully,remember the spring? LOL) to determine that.
As for the oven it may be clogged ports in the burners etc.Or they just need adjustiment by a certfied gas technician. Don't fool with it yourself gas is dangerous.So if your getting someone in to fix the gas problem have them fix the door as well.
Aug 03, 2009 | Garland H283 Gas Kitchen Range
Oven does not bake evenly.
We placed the pan in the exact center of the oven and backed it for 10min longer than what the recipe stated.
Dec 29, 2008 | Whirlpool SB160PEE Gas Single Oven
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
GE XL44 Working fine but awful burnt propane smell
Remove the burners and clean them with EASY OFF oven cleaner. The passages are likely plugged and this causes incomplete burning of the gas. If you do smell raw gas shut the gas to the stove off RIGHT AWAY and call the local gas supplier.
May 12, 2017 | Kitchen Ranges
Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Jan 24, 2008 | Whirlpool SB160PEE Gas Single Oven
Stoves 850DODLM Gas Kitchen Range Logo
67 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
