Question about Kyocera FS-4000DN Laser Printer
Kyocera fs1020d printer powers normally but does not pick the papers.
  • Kyocera Master
  • 1,113 Answers
Needs new feed roller, just clicks out, remove paper cassette see middle front.
Posted on Jan 15, 2008
  • Soulvisitor
    Soulvisitor Jan 16, 2008
    Thanks for bothering to rate it is appriciated
    The original rollers were smooth, the kyocera new improved ones now have grooves
I need setup for kyocera fs1020d can anyone provide a link?
http://driverscollection.com/?H=FS-1020D&By=Kyocera
May 27, 2014 | Office Equipment & Supplies
Kyocera fs1020d only prints 1/2 page?
needs realinded,remember the first set up,it printed a page,look it up online and run the start up series on it again,if not,you have a printer or roller bar stuck.
May 25, 2014 | Kyocera Mita FS-1020D Laser Printer
Paper is not picking up from paper tray but
Pickup rollers can lose their grip from paper fibers and the surface of the rubber drying out. They occasionally need to be accessed for cleaning. Use a fiber-free cloth or paper towel and scrub them with a little naphtha. Using low-grade paper can clog them quicker.
Mar 09, 2011 | Kyocera FS-1030D Laser Printer
Kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
Error message - "chassis locked"
check the toner on the left had side is a locking mechanism... make sure toner is in correctly and that switch is locked...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Mar 23, 2009 | Kyocera Mita FS-1020D Laser Printer
My Kyocera Mono Laser Printer is stopping between each page
call a service technician to clean the paper feed rollers... they aren't picking up the paper... this triggers the error so you have to stand there and manually reset the error and it prints...
Jan 21, 2009 | Kyocera FS-1030D Laser Printer
My Kyocera FS1020D won't print. The light says i need new toner - but the cartridge is relatively new. And you can hear the toner inside the cartridge when you shake it. I've tried switching computer and...
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Kyocera Mita FS-1020D Laser Printer
Can the kyocera fm1500 be used as a shared printer? I wondered if i can network this and replace my kyocera fs1020d which is on its last legs
I don't believe the 1500 has printer capability. you would need an 1820 for full interface capability.
Mar 05, 2008 | Kyocera KM-1505 Copier
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Kyocera FS-1920 won't pick up paper from tray
replace pick up rollers and paper tray roller. Take out paper tray and toner, lift printer so you can see underneath you should see a set of rollers its nopt to hard to get out. also in the paper tray there is a roller swop that out to
Dec 14, 2006 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-4000DN Laser Printer Logo
124 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
