Question about Bose Wave Radio
Boes wave radio
When turned on nothing no clock nothing
    Scholar:
  • 67 Answers
All Wave Radios have a Pigtail fuse on main board. May just be Fuse. I have seen alot of them that when dead have water damage as root cause. These radios are very reliable and water damage failure seems to be the most common. Bose has a flat rate repair service on these radios http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/contact/index.jsp&ck=0
[email protected]
Posted on Jan 14, 2008
6ya staff
SOURCE:
My bose wave radio 1 somehow switched to military time. There is no clock set button?
Not explicily, but on page 18 of the manual (Bose.com) clock setting is explained...
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Sep 08, 2011 | Bose Wave Radio
When I plug my Bose clock radio into one outlet, I get nothing but static. When I plug it into a nearby outlet (with out really moving the cord), I get perfect reception. The problem is the outlet where...
The Wave Radio uses the AC power cord as an antenna. Perhaps the two outlets are wired differently regarding ground and hot.
An interesting article...
http://www.gcaudio.com/resources/howtos/acpolarity.html
As the man says in the article thecircuit tester like this...
http://www.idealindustries.com/products/test_measurement/electrical_testers/circuit_tester_e-z_check.jsp
... can be found at many Dollar Stores for cheap.
Mar 06, 2011 | Bose Wave Radio
After a power outage, my Bose radio went to military time. I've tried to re-start it by unplugging, re-unplugging, etc. Help!
To switch between 12hr and 24hr format:
1) Turn your Wave Radio off
2) Press and hold "Clock Set"
3) Press "On/Off" to switch between 12hr or 24hr format.
Dec 27, 2010 | Bose Wave Radio
Unit is plugged in but no lights, no sound, nothing....can hear a slight pop in speakers when it is un-plugged
Bose Wave Radio/Cd. The radio has no sound, no lights just dead completely. No power. Just died on me one morning.
Dec 12, 2010 | Bose Wave Radio
My bose wave radio won't turn on at all. replaced 9 volt battery.
open unit up and check A/C FUSE located near where the A/C plug/wire is connected to radio!
If fuse is bad it will measure an OPEN ]---- ----[
a GOOD FUSE will measure a SHORT ]-----------[
gl
May 19, 2010 | Bose Wave Radio
Bose wave Radio/CD Awrcc1...clock powers up for about 2 seconds then goes dark, nothing else will work.
your SOPS powersupply is defect.
replace 1 elco 100/25V and 1 resistor 470kohm and it will be fixt.
this parts are lacated near the transformator and AC connection
the same aera where you will find a big elco with value 100uF/400V
Feb 10, 2010 | Bose Wave Radio
Bose Wave unplugged now it won't power up when plugged back in
I will first start check the power section circuitry of your Bose Wave radio. Are you electronics savvy?
Jun 16, 2009 | Bose Wave Radio
Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Apr 09, 2008 | Bose Wave Radio
Clock on Bose Radio
Push & hold Clock Set Button. While holding, push On/Off button,
Thank You, FixYa Community! Thank you! Thank you! Boy, that one was not obvious.
Nov 06, 2007 | Bose Wave Radio
Display Off/Wave won't turn off
I just purchased this clock too, and I can't get the Wave to turn OFF ! I have my alarms set to wake to radio...the Wave function is supposed to only function if you have the clock set to wake to buzz.
I may have to put a piece of duct tape over the Wave sensor to disable it.
Jul 15, 2007 | Emerson CKS3020 Clock Radio
Bose Wave Radio Logo
537 people viewed this question
Top Bose Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
