Question about Lenovo Thinkpad T60 Notebook
T60 will not boot up
Error message:
2100: HDDO (Hard Disk drive) initialization error (3)
  • kisho Feb 24, 2009
    My R 61 one showing the same prob its not booting , displayong
    2100:HDDO (HARD DISK DRIVE) Initialisation error (2). please suggest me a solution....
    Problem Solver:
  • 5 Answers
There appears to be a BIOS update or two available for the Lenovo TP T60. One of the updates makes reference to this error code, but the verbage afterwards is a little different to that posted here. Mind you, my recommendation is that you should stay on target with BIOS updates because they are fixing problems with the computer, even if you don't realise you are having those problems!
Please go here:
Press Ctrl F and search for 2100. This tells you which update fixed a problem with ERROR 2100: At the bottom of this page you will find that these updates are for all regions. You will also find the link to the BIOS update utility.
My experience of BIOS updates on the Thinkpad range is that you have to undock the laptop prior installing the BIOS update, and ensure the laptop has a constant power support - NOT BATTERY. Ensure you read the on-screen notes carefully.
Hope this helps.
Posted on Jan 14, 2008
Posted on Aug 22, 2010
3 Suggested Answers
  • 19396 Answers
SOURCE: lenovo T61error 2100: HDD0(hard disk drive)
To all users with: lenovo T61error 2100: HDD0(hard disk drive),
Possible cause:
  1. Corrupted hard disk logical sectror/hard disk logical error (bad format).
  2. Hard disk connector not well in place.
  3. Hard disk broken, physical fault.
  1. Format hard disk and reinstall system using a Windows setup CD.
  2. If that does not work the Hard disk must be removed to check thge connector, and to test the hard disk on a different computer.
  3. If the hard disk is bad , it must be replaced, and windows reinstalled repeating step one.
Posted on Jan 07, 2009
  • 146 Answers
SOURCE: i can't boot up. it display error 2100: Hard disk
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive.
Try this:
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Boot from either your emergency repair disk, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
If the above fails:
Verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
If all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Let us know how it works out.
Posted on Jan 11, 2011
How do I correct Error 2100:HDDO Hard disk drive initialization error 1
I would remove the corrupt drive and connect via USB to another computer running Win7. See if the computer sees the drive. If it does, put it back in the laptop and try booting again. If not, go to Control Panel, disc management and create a drive letter. Doesn't matter what it is. It should then boot OK. If not, replace the drive.
Aug 01, 2015 | Lenovo ThinkPad Computers & Internet
Thinkpad T60 hard disk drive error, cannot boot from any device
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 21, 2013 | IBM ThinkPad T60 Notebook
Check cable connection..! PXE-E63: Error while initializing the NIC PXE-MOF: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key
Hard drive is not detected. Change the Boot sequence in BIOS
1. To access the BIOS you must tap F2 or delete key upon turning the computer on
2. Try to look for the Hard drive if it is detected by BIOS if not got to step 6
3. Look for Boot Sequence or anything that is associated Boot
4. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
5. Save the changes and Restart
6. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
7. If Step 6 did not work I think you need to replace the Hard drive
Thanks for Choosing
Jun 16, 2011 | Acer Computers & Internet
Acer aspire will not start. get message check cable connection! PXE-E63 error while initializing the NIC PXE-M0f Exiting Intel PXE ROM No bootable device - insert boot disk and press any key. Netbook has...
1. It seems that the hard drive is not bieng detected by the computer 2. and from the error message that you are getting it seemed like windows is not loading up 3. I would suggest that you take out the hard drive and put it back in 4. the reason for that is the hard drive that connects from the mainboard is
May 29, 2011 | Computers & Internet
PXE-E61 Media Test Failure Check Cable on compaq presario 2100
A PXE-61 error message is most likely a faulty hard disk.
Try reseating the hard drive first and if you still get this error message again then you need to replace the hard disk.
To boot up with the CD you maybe able to press the F12 function key when you power up the laptop, this will bring up the a menu option to select an alternate boot device. If this option is not available then go into the BIOS configuration and change the bootup order and make the CD as the first boot device and the hard disk as the second device. You can can it back later.
Sep 14, 2009 | Compaq Armada E500 Notebook
2100: HDD0 initialization error (2)
same prob on my IBM LENOVO T60
did anyone found the solution?
please contact me
i need to recover my DATA
my pc can't start no more
Aug 11, 2008 | Computers & Internet
Seems the harddrive has failed, and needs to be replaced.
Aug 11, 2008 | IBM ThinkPad T60 Notebook
Lenovo Thinkpad T60 Notebook Logo
2,788 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
