Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Amana French door Refridge-water dispence inside the door not working
The water dispenser inside the door is not working, changed the filter, motor is running but no water. Ice maker is working and we are stumped. Before I changed the filter, it was running very slowly, then quit and then worked again for a few days...Please advise
    President:
  • Frigidaire Master
  • 2,651 Answers
Pull out crisper and deli shelf thers a tank behind them its probably froazen, hit it fora few minutes especally around top neck portion with a hair dryer, common issue
Posted on Feb 23, 2008
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Water dispenser inside my maytag MFD2561 refrigerator is not working. what could be causing this problem and how do i fix it?
check water supply
check water valve
check filter
check for frozen water tamk
if none of those are bad check the switch at the control,
Jul 14, 2009 | Amana AFD2535DES French Door Refrigerator
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Intermittantly no water from inside water dispenser
I just started having the problem of no water dispensing from the in-door dispenser. I checked the operating manual and it suggested that the refridge temp may be set too low thus freezing up the water line. I have set the temp higher and we will see if that helps. I do not think that will do it because as you too note, the ice maker works fine. If the filter were an issue the ice maker would not refill either.
illinoisjas
Apr 19, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
No water supply to water dispencer
I had this problem with an old amana and my water filter neded replacing. Filter was enough for ice but not for water dispenser.
Mar 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
196 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
