Question about Kitchen Ranges
GE XL44 range control panel not working
There are no indicator lights working on the control panel
  • 4 Answers
The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Posted on May 18, 2007
  • 5 Answers
SOURCE: How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Posted on Mar 22, 2009
SOURCE: GE Spectra XL44 Gas Kitchen Range - suddenly only top works
where do I find the pilot light?
Posted on Jul 04, 2009
  • 82 Answers
SOURCE: i have a ge xl44 gas range. the oven knob has come off
You will need to locate your full model #, usually open the bottom drawer and you can see it on the chassis on the right or left side. Try type your model in and it will give you a parts breakdown and about the best assembly view your going to get. Sometimes there is more to be desired but this should help. Please rate this post.
Posted on Dec 14, 2009
  • 221 Answers
Sounds like your igniter has become weak, it will need to be replaced.
Posted on Mar 17, 2010
  • 385 Answers
SOURCE: The oven will not light.. ge xl44 range/oven 10
More than likely you have a bad oven ignitor. It's not uncommon that they need repalced, they do go bad.
Posted on Mar 13, 2011
0 characters
1 Points
We have a GE Profle XL44 Self Cleaning Dual Fuel Convection range that just started displaying an error code "F0". What is the issue? Can the oven/stove top be used while assessing this...
F0 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Aug 08, 2011 | GE Profile 30" Self-Cleaning Slide-In...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE profile XL44 code F7 & FO readng on
    Turn the circuit breaker off at the switchboard for a minute then back on again. This may reset the electronics.
    Nov 22, 2009 | GE Kitchen Ranges
    Short on range wont work
    Check for power to the primary transformer on the control. You probably blew out the controller if you find 120 volts present to the board. You may also have blown the coil on your gas valve. Be careful here!
    Dec 12, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Top works bottom doesn't
    I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
    Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
    Control panel shows F7 and contantly alarming or beebing
    F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
    1. Pushing CLEAR/OFF pad.
    2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
    If code recurs, problem is in the control. Replace control.
    If code does not recur, problem is with the Key Panel.
    Oct 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    Kitchen Ranges Logo
    204 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Barrett Palumbo
    Barrett Palumbo
    Richard Roth
    Richard Roth
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
