Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kenmore model 10657
How do I change out the switch at the water release in this refrigerator? I don't want to break the trim piece on outside of fridge...Does this trim piece just pop off?
    President:
  • KitchenAid Master
  • 2,651 Answers
Yea it should pop off. look under facade trim should see 2 indentations for inserting a screw driver. care fully insert a flat blade and gently twist relaesing the plastic tabs, i find usefull to also push down on leading edge if dispensor facade(right above the indentations,
Posted on Feb 22, 2008
How to replaced a 2003 Malibu heater switch
Center instrument panel trim bezel-- on models where the ignition switch is mounted behind this bezel, use a small, taped screw driver to pry off around ignition switch. the switch stays in the dash. pry around the trim bezel with a flat tool to remove trim. to release the clips. ( Be careful not to break the trim around the controls). Remove the screws from heater assembly, and pull out just far enough to remove vacuum hoses and electrical connections. Use a small screw driver to release the clips from assembly. When installing switch, Do not use oil on the hoses to make them slip on better. it will mess up the vacuum needed for proper operation. If needed use water for the hoses.Good-Day!
Sep 02, 2014 | 2003 Chevrolet Malibu
How do you install a driver seat plastic shield on a 2004 Ford Explorer? Its the piece of hard plastic between the door and the seat - part number 1L2Z-7862187-BAC
see if this helps
  1. Remove the rear trim screw.
  1. Remove the lower trim screw.
  1. Release the side trim front retaining clip.
  2. Pull the lumbar mechanism out slightly from the seat.
  3. Push down and pull out, releasing the side trim front retaining clip.
  4. CAUTION: Take care when removing the side trim cover. Excessive force will break the mounting tabs.
Release the side trim from the mounting bracket.
  1. Disconnect the seat control switch electrical connector.
Mar 25, 2011 | 1998 Ford Explorer
I have a GE side by side refrigerator (Model #GSL25JFXLB) and the ice and water dispenser stopped working. Any suggestions?
THE first thing i would ask are you still making ice in the ice bucket and just that it will not come out of the door... if so it is going to be a problem with the dispenser actuator or the micro switch in the door. there is a small pc control board in the dispenser area they may also be affected.. will require you remove the trim piece around the dispenser usually under the water overflow in the door once you remove it there will be 2 screws take them out ..if your do not have the screws on the side of trim you will see notched out area on each side the carefully a screwdriver can be put in and pop the trim piece off. check the switch with the door actuator is it making contact.if you are not getting water or ice production has stopped i would say check your filter first/next check to see if behind the produce drawers you have a water storage resorvoir make sure it has not froze up... lastely check the water valve to make sure you are getting 120 volts to water valve when the door switch is pushed ..hope this helps post with more info and any other questions you have....good luck to you...
Feb 11, 2011 | GE GSL25JFXLB (250 cu ft) Side by Side...
I need to replace the control board for the ice dispenser. How do I remove the cover to get to the module. I tried prying off the cover but am afraid it is going to break. I am not sure where I should pry...
All you need is your kenmore model number and replace the dual water control valve on rear of your refrigerator. They have one side for ice maker and other is for water dispenser. You can test the voltage for 120 volts as someone presses dispense water. Most likely the coil that opens the valve for water is defective. Sea Breeze
Mar 25, 2010 | Kenmore Refrigerators
How do i replace left door mirior
remove trim panel, remove mirror fasteners.
Glass, Outside Mirror—Town Car
Removal and Installation
  1. Push upper edge of outside rear view mirror glass (17K707) into the outside rear view mirror to expose latch release.
  1. Using a small flat-bladed screw driver or equivalent, move latch release to released position.
  1. Remove outside rear view mirror glass mounting back and outside rear view mirror glass from outside rear view mirror.
  1. Disconnect heater wire connectors and auto dimmer connector, if equipped.
  1. To install reverse Removal procedure.
Mirror, Power—Outside Rear View
Town Car
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove front door trim panel (23942). Refer to Section 01-05 .
Trim Panels, Door Front—Town Car
Removal
  1. Snap out two door pull strap retaining screw covers. Remove screws.
  1. Remove three screws on front and rear side and center of front door trim panel (23942).
  1. NOTE: The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
    Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
  1. NOTE: Do not use front door trim panel to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
    Remove window regulator control switch housing from front door trim panel. Lift up housing in front and disconnect all connectors.
  1. Disconnect wiring harness and heated seat switch electrical connectors if equipped.
  1. Remove the door trim panel.
  1. Disconnect two electrical connectors.
  1. Remove nut from outside rear view mirror mounting base.
  1. Swing outside rear view mirror (17682) toward driver door window glass to expose screw in mount base.
  1. Remove screw from outside rear view mirror base.
  1. Remove outside rear view mirror from front door (20124). Guide wiring and connectors through hole in front door.
  1. To install, reverse Removal procedure. Tighten nuts to 8-10 Nm (71-88 lb-
Nov 05, 2009 | 1996 Lincoln Town Car
Kenmore side by side refrigerator
If you are asking about the dispenser lever, There is a good chance it is already broke. You will need to remove the front cover. On most models, you will need a standard flat blade screwdriver and then locate the indentations on the underside of the cover trim. It takes a little force to pop the cover trim away from the door, but it will come loose. Once you have removed the cover, the dispesnser levers should be visible.
I hope this will help you to at least determine weather you can just tighten it or need to replace the lever. Please let me know if I have helped you. I can also look up the correct part and get it shipped to you.
Hope I helped
Vic
May 08, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore - Side by Side condensation in water/ice dispensor area
maker sure your flapper is closing all the way the trim plate will come off its snapped on once you get it strated it will come they are a bear use butter knife to pop it loose on cornor first hope this helps
Sep 13, 2008 | Kenmore 53642 / 53644 Side by Side...
I have the opposite problem
You may have air in the system. When you actuate the dispenser it opens an electric valve in back to start the flow of water. When you release the dispenser air in the system expanding will cause the water to continue to flow until the pressure equalizes.
May 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water Dispenser on Freezer door leaks
Some of the trim plates need to be pulled downward quite hard to get them to release. Pull any drip tray out then pull downwards on the bottom part while trying to pull outwards too. Try that and let us know.
Feb 27, 2007 | Kenmore 56272 / 56274 / 56279 Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
