Question about Neff 28 in. T2766 Gas Cooktop
Automatic ignition 'clicks' and 'sparks' non-stop
The hob is dry, but when the electricity switch is on, the clicking and sparking is non stop.
As far as I can see all the points are clean.
Can you me how to solve it, or does it need a new part ?
Thank you, Lillian Connor
  • 4 Answers
Switch and spark module,
Posted on Jan 20, 2008
  • mackattack Jan 20, 2008
    order switch, and module
The igniter on my GE cooktop wont stop clicking, only if i unplug it.
Spark module part no 318 at parts diagram it may be wet and by using a hair dryer or leave it unplug for some days can dry out and stop. If not then the electric contacts are stuck and need a new spark module
Aug 27, 2011 | GE Profile JGP636 Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
All 4 of the hobs started sparking/ clicking after cleaning the cooker top. Now they won't stop sparking/ clicking.
there is probably some water in unit that is causing the unit switches to not work. you can try to use a hair blower to thoroughly dry components.
Feb 26, 2010 | Smeg 23 in. SE64 Gas Cooktop
Duvalli GHG604B gas hob ignition problem. Ignition has stopped working. Everything is clean and dry. Power and fuse is O.K. I suspect the spark generator unit, but how can I test?
If you know the power and fuse is ok, and none of the knobs will turn on spark, the only thing left is the spark module. The switches would never all go out at once.  Good luck
Jan 07, 2010 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Electric starters keep firing after I sprayed cleaner
your spark modual got shorted with the liquid you sprayed in there or spilled you can try unplugging it overnight to let it dry. at least 24 hours or you can take the cooktop of and get a hairdryer and dry out the spark modual.or if you wait 24 hours - 3 days and still not dried out you need to replace your spark modual but more than likley give it time it will fix itself.
Apr 23, 2009 | Amana AKS3040 Gas Cooktop
Hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Automatic Eletric Ignition stopped working
It's is normal for the ignitors not to work when wet, once they dry they should work. The best thing is to check the electric sending unit, they are a small white kind of square that goes on the switch, just lift the knobs and take the cover of the switches and you should see the sending units righ on the rod that hold the knobs, they have to small wires attached to them, It seems to me that thats were your problem is.
Do you hear the click clik when you put the knob on LITE??
May 19, 2008 | GE 30 in. JGP336 Gas Cooktop
Neff 28 in. T2766 Gas Cooktop Logo
897 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
