I have a 2002 chrysler 300m with a 3.5 high output engine. I replace the engine frome a 200 chrysler 300m 3.5 high out put. Now its hard to start and I get p0016 and p0344 codes all the time
Hello, Had the same problem but i did just the opposite I put a 2002 engine in a 2000. I found out that the cam sensor spocket (for the timing belt) Has the holes for the cam sensor in a different spots causing all kinds of problems also they did the same with the flex plate so I hope you took the one off the 2002 and used it or you will have to pull it back out and change it. Good luck
