Denon UD-M30 (CD Receiver) bought U.K. using in apt.Fuerteventura
Massive sudden increase in volume 15 to 30! Can this be a remote device being used by a neighbour? Can't think of anything else! Using a "surge protector" bought in Fuerteventura, but don't know what else to do. Can't ask neighbours to stop using their own devices, and anyway Spanish is not good enough to explain problem. Has anyone else had similiar problems?Will be devastated if we can't play our music!
Hope somebody out there can help!
Regards from music lovers
  • Anonymous Mar 28, 2009
    happens even with no batteries in the remote
  • 45 Answers
It is more likely your remote has a stuck button. If your device is not UHF, then your neighbors remote will not affect you.
I would check your remote first. Remove the batteries on your remote, and see if that fixes it. Then put the batteries back in, and see if your units volume goes up again.
Posted on Jan 14, 2008
How to set time on denon ud-m3
press 'display' for 4 sec, then change hr with left arror, min with right arrow. easy
Mar 26, 2012 | Denon CDR-M30 CD Recorder
I need to find the instruction manual for a Denon UD-M30 CD Tuner. Can you help please?
You can get the manual on the link below. Just click on where it says it is free.
Good Luck please rate 4 thumbs and please leave a testimonial
Oct 05, 2010 | Audio Players & Recorders
Denon ud-m30 Tuner problem I can tune am stations, but not fm. Receiver doesn't even receive signals from my nokia n97 transmitter 5 cm away on the known frequency. Is it possible that fm unit is out of...
I have just solved this problem with my system - it is caused by bad connections between the boards. There are multipin connectors that connect the main boards together via a small vertical board. Check that these are fully connected and you will probably solve the problem.
May 30, 2010 | Denon D-M30 CD Shelf System
Denon CD receiver - Auxiliary function not working
this is front headfones nearby cd player control knob
Nov 22, 2009 | Audio Players & Recorders
Try looking into the lens (power off) with a magnifying glass. If you see any damage you will need to replace the lazer/lens section as the lens will never be able to read the disc.
If it's clear it's more likely to be an electronic fault.
Aug 26, 2009 | Denon CDR-M30 CD Recorder
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
No Aux on a UD-M30
We had the same problem, found that if you plug your device into "line 2 in" on the back and select tape it worked for our ipod. We had to turn the volume right up on the ipod to hear it though
Nov 12, 2008 | Denon CDR-M30 CD Recorder
Disc reading
How confident are you at opening it up? And where are you? If it can get table of contents info it could be gummed up grease on the laser sled.
Jun 15, 2008 | Denon CDR-M30 CD Recorder
Denon ud-m30
Yes it maybe a laser,if the repair cost still reasonable,why not.
Dec 14, 2006 | Denon CDR-M30 CD Recorder
357 people viewed this question
