Question about Philips LX3700D System
Philips lx3700d xbox 360 connected with microsoft vga cable to tv. optical sound cable from xbox to philips lx3700d surround sound system, but no sound
  • 8,596 Answers
This HTS can't read opticals
Posted on Mar 20, 2008
Connect xbox to philips hts2500
you can use a special audio cable avalible at walmart http://www.walmart.com/ip/Axis-41248-Axis-Digital-Optical-Toslink-Cable-6/21089610
OR
buy one of these and hook the white and red audio cables to the imput on the surround sound
http://www.bestbuy.com/site/eForCity+-+Optical+Audio+Adapter+for+Xbox+360+HDMI+AV+Cable+Gaming+-+Gray/4338413.p;jsessionid=1645495912DD7B9466A02420184C1551.bbolsp-app04-148?id=1218475496784&skuId=4338413
Mar 25, 2013 | Philips Immersive Sound Home theater...
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Nov 26, 2011 | Philips Audio Players & Recorders
Hello, I recently hooked my Xbox 360 up to my surround sound system using a digital optical cable ran from the xbox to the TV (optical cable from 360 to sound system) Sound and video works great for...
HDCP is the "handshake" protocol used by the Xbox to communicate via HDMI to your TV. The optical cable wouldn't have anything to do with this error. So far the only solution that's been found to this issue is to ensure that the HDMI cable is properly plugged in and power off/on both devices and see if the handshake is restored. If this doesn't work you may need a new HDMI cable.
Jun 27, 2011 | Microsoft Xbox 360 Console
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
Can xbox 360 be connected to suuround sound
yes! plug component cables (RED/WHITE)
in an AUX port in a surround sound system...select AUX on your system..
plug YELLOW into TV
play!
Feb 07, 2010 | Microsoft Xbox 360 Console
The LX 3750 dvd surround sound. Is the audio
It has a coaxial digital input. For whatever reason, they did not provide on optical one. This is not uncommon.
Jan 31, 2010 | Philips LX3700D System
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
I am using my xbox 360 via HDMI, and I have a 5.1 surround sound system hooked up via RCA output from the tv. If I switch it onto the coax input it works, but when I switch to HDMI it doesnt. Is there a...
no, there's no firmware upgrade that you can do on the tv. the reason for that is because you are sending digital sound to the tv with hdmi from xbox 360,and when you have rca cables connecting your tv and surround sound, the rca cables provide stereo sound. what you need to do if you want to use hdmi is connect optical cable from tv orxbox 360/ or tv to your surround sound to get digital sound, and it will sound better digital sound.
Apr 17, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Need to connect xbox 360 to panasonic sa-mt1
If you want to play 5.1 sound, and you got to need this fiber optic cable(black single cable)..with reciver decoder with optical on IN, to connect the xbox 360 machine on, and the high defintion cable of the xbox.
Feb 19, 2009 | Panasonic Home Theater System System
Philips LX3700D System Logo
248 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
