On start-up, the screen flashes off and on every few seconds, then after about 2 hours suddenly starts working. When I say flashes off and on I mean the screen is black, and then for a millisecond the desktop picture will appear and then it goes black again.
-   My screen will flash for hours on end.. My monitor just came on after 2 days of flashing.. I'm shopping for a new monitor unless there is something I can do to fix this issue myself. Thanks-   gonzo1510
Oct 24, 2008
-   I have HP Pavilion notebook - it is back at HP AGAIN, second time after over 12 hours on phone with technical support, exact same problem, they can't fix it, don't know what to do. Just purchased it $1200 in Feb 08, very frustrating.
-   Mine will come on normally for a second or so, then goes blank. Turning it off/on just repeats the problem. I'm hoping for a solution I can perform myself.-   rmg1600
Apr 17, 2008
-   When I start up my computer it goes black and I have to mash the monitor power button to get it to come back up. It stays up for about 2 seconds and then goes black again. I do this repeatedly until finally it just stays up... by repeatedly I mean approximately 50+ times. Very frustrating. What can I do to fix this problem?-   Canky
Apr 02, 2008
-   video card is working fine. tried the monitor on 2 different machines and got the same result. a brief screenshot then a blank (black) screen. all connections were solid.-   Guest
constant blinking of osd lock and other menu options.besides contrast and brightnessgets adjusted on...
(More)
CONSTANT blinking of OSD lock and other menu options.besides contrast and brightnessgets adjusted on its own.how to solve this?
My 20" apple cinema display has what appears to be interference. Rapid blinking horizontal...
(More)
My 20" apple cinema display has what appears to be interference. Rapid blinking horizontal lines, that slowly move vertically up the screen. They get better the longer it's on, but never fully go away. I have tried plugging it directly into the wall outlet, no change. and it does this when hooked up to either of my macs. Is it dying?
I have a Viewsonic VG2230WM model# VS11422. It has several blown capacitors on the power board an...
(More)
I have a Viewsonic VG2230WM model# VS11422. It has several blown capacitors on the power board an the mossfets show signs of overheating, but they are pretty rugged (will replace anyway). I foind a componant that seems to have overheated and shorted it's at location RT100 just behind the main power connector and fuse F101. What is it? If it is a resistor what is the resistance it should be at? (exterior discolored) Where can I get a wiring diagram? (to findout if you guys don't know)
The Menu section keepspoping . I press the menu button on the bottom right of the screen and after a...
(More)
The Menu section keepspoping . I press the menu button on the bottom right of the screen and after a few moments the menu pops back up and wont go away, ive rebooted unpluged everthing mIcan think off it wont stop coming back up and peventing me from seeing whats on the other side I havea hp w1907 widescreen
