Routers
Problem for Routers
Generic problem for all Routers
BEETEL 220BX ROUTER
By Lakshmikanth on Jan 14, 2008
sir, early i had airtel connection and airtel broadband. now i got the BSNL connection. now there is no airtel connection. But i want to RESET the earlier BEETEL220BX ADSL2+MODEM AND AGAIN CONFIGURE BSNL TO THIS. How can reset this? and how can configure BSNL to this?
Same Problem
Aug 12, 2008
-   I HAVE SAME PROBLEM BUT I HAVE NOT WIRELESS ROUTER & OUR ISP IS MTNL DSL CONNECTION NOT BSNL-   deepakray89
Best Solution
posted on Jun 18, 2008
Helpful)
abifixya
Rank: Apprentice
Rating: 88%, 2 votes
First login to your Router using default username and password
2. Click on WAN on the left side menu
3. You'll have options to add or remove configurations.
4. Please select and remove the bridge config as BSNL does not support Bridge.
5. Please click edit on the existing PPPoE Airtel Configuration
6. Set the VPI=0 and VCI=35 (for Airtel it would be 1,32) and click next
7. Select PPP over Ethernet (PPPoE) and encapsulation type: LLC/Snap Bridging and click next
8. Enter the following details:
PPP Username: Your bsnl username (no need to add dataone.in)
PPP Password: Your bsnl password
PPPoE Service Name: DataOne
Authentication Method: Select CHAP
Click Next
9. Check the Enable IGMP Multicast Option
Check Enable WAN Service Option
Enter the Service Name as Dataone
10. Click Next and Save. You should also save and reboot your modem.
If doing the above does not works, check if you have anything set Under TR-069 Client and remove all entries in this section however it may not allow you to save so you may just put the ACS URL as ( it won't accept this field to be blank so just enter any thing, I entered http://bsnl). Save and reboot the router. Should be online now.
let me know if anyone benefited from the above information - abialexin@yahoo.com
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 15, 2008
Not Rated)
nucleusin
Rank: Apprentice
Rating: 0%, 0 votes
we are also having same problem , now we want the router be used on mtnl triband
Was this helpful?
Yes
No
Solution #3
posted on Feb 06, 2008
Not Rated)
Xsugarbox
Rank: Guide
Rating: 88%, 15 votes
If you are wanting to reset it back to its default settins, while power is on reset the little pin hole button for about 20 seconds and let go that will reset router. not sure on how to configure BSNL
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
Hello! I can't connect my Xbox 360 into LIVE because the MTU always fail, Where do I change the... (More)
Answer
Trying to access netopia 3347 router from my home to moitor dvr cam system
Answer
I am trying to get my IP camera to work
Answer
How to set 3com 3CRWDR101A75 router standard to g.dmt explicitly?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 1451
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
