Question about Epson Stylus CX3200 All-In-One InkJet Printer
Does not scan to file!
Prints from file, copies and prints but does not scan to file! scan button does not respond!
  • 619 Answers
Try to download driver to epson here below for convenience.
TWAIN Driver and EPSON Scan Utility v3.04A
Posted on Jan 14, 2008
Scanning takes an image on a document on the scanner's platten and converts it to a digital file format stored on your computer.
Copying is scanning + printing.
To copy, you do not need to separately scan first and then print. Just select how many copies you need on the number pad, then press either the Black or the Colour COPY buttons on the scanner (or open the printer's/scanner's software and click on COPY), while it's connected to the computer and the document will automatically be scanned and printed (copied).
I hope this helps.
Aug 24, 2011 | Office Equipment & Supplies
Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer: Hello, I have a Xerox Phaser 3300MFP and there are...
Primero , apaga el sistema y desconecta la energia
Luego hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
May 06, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Scan feature greyed out on Toshiba eStudio 232
You have to have the USB stick to enable the scan.
It locates on the right side near the back of the machine.
They make , print dongles, Scan dongles and print scan dongles. But that USB device enables scan.
May 04, 2009 | Toshiba e-Studio 232 Black and White...
Lexmark x75 does not scan or copy from the device nor on the pc
I have to know what are the things you tried. But still i will let you know what you should try. Reinstalling your device by first uninstalling your device and using any disk cleanup utility to clean the disk so that old corrupted files are removed. You can also try to look for troubleshooting help in the software CD which came along your device. you can also go to the companies website for troubleshooting. They will ask for the device code and some information. Usually this error comes when the driver installed for the device is corrupted or gets corrupted.
If my advice helps you out, please feel free to rate me.
Mar 22, 2009 | Lexmark X75 All-In-One InkJet Printer
From that, am I right to assume anything you print/copy comes out blank?
If it sounds normal otherwise, I would suggest trying to change the ink cartridges as they may be empty or dried up.
Dec 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Ricoh Aficio 2090 Printing config question
You have to scan each one individually. The machine can scan them into a pdf file. Press user tools button. Press the scanner button and check the file format settings for individual files. Select PDF if needed.
Nov 13, 2008 | Office Equipment & Supplies
Problem with scanner
Try to get the scanner operating by using a programme such as paint (open file from scanner or camera) or powerpoint (insert picture from scanner or camera). I have used this with success in the past. I have not used the scan button so I cannot advise you on this.
Hope this at least gets you going with scanning a copy of something and once you have it in these programmes you can at least print it and make some changes that you desire.
Hope this helps.
Youre right - they are a great printer!!
Apr 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Lexmark X1185 won't scan.
I have the same issues with a Lexmark printer, Lexmark printers are not very user friendly with Vista. What I did is create a dual boot with XP and installed the software for the printer there. If interested in that follow these instructions or contact lexmark support.
Nov 08, 2007 | Computers & Internet
I believe you have to push the scan button in order for it to scan and save. The copy buttons will only print either a black copy or a color copy.
Sep 12, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Epson Stylus CX3200 All-In-One InkJet Printer Logo
146 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
