Water not draining, can't open door
I Have been putting hose into bucket to water garden, I think the water has backed up,  I have tried every setting nothing happens.  Can't drain machine, open door and remove washing.  HELP!
    President:
  • 1,294 Answers
Press "end of cycle" button & wait for 2 minutes before trying the door. Machine shd be 'on'. Then plug off the wall & below........
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 15, 2008
How do you drain the tank to put new alternator in. Is there a special drain hole to put into buckets to save the water fir the garden?R
I can't answer specifically to your brand, but any we have ever had would have a drain down low, generally towards the back, where you can attach a standard garden hose on it to direct the water outside. From there, as long as it's below the level of your drain, you can let the hose drain into buckets. The buckets just need to be "downhill" from the drain or the water won't drain, it will only sit in the hose. Water needs to travel downhill.
I like that you are wanting to salvage the water in your tank for another purpose rather than wasting it. *thumbs up*
Aug 13, 2015 | Water Water Heaters
How do i drain the washer for moving it
Mike,
I cannot tell whether you are talking about (1) the little bit of residual water in the machine after it's done, or (2) about a machine that's stopped mid-cycle with a good deal of water, so I'll respond to both cases.
(1) The lowest point in the washing machine is the drain outlet at the back to which the drain hose attaches. First remove the free end of the drain hose from the drain pipe and place it in a bucket sitting on the floor. That will get most of the water. Then place a towel on the floor and remove the other end of the drain hose from the machine. Remaining water will spill out from the outlet and hose onto the towel. You might get a little more if you lift the front of the machine, tilting it backward.
(2) If you can't drain the machine and it's full of water, you will need to siphon it. Take a piece of tubing, at least five feet long. You could use a piece of garden hose if you have nothing else. If you don't have a door or window nearby, you will need TWO buckets. Place the buckets on the floor in front of the machine. Place the siphon hose into the washer tub starting with one end to fill it with water. When it's completely in, cover one end, take it out, place it into a bucket. If the siphon doesn't automatically start, get down low on the floor, place the hose into your mouth and inhale. You may have to do this several times, possibly covering the tubing end with your tongue between inhalations. When the bucket is nearly full, switch the hose to the empty bucket and empty the first one. You will probably have several buckets of water. (Of course if your washing machine is near an outside door, you can simply start the siphon outside and omit the buckets.)
Oct 02, 2014 | Washing Machines
Sewage backing up into laundry room when we use our dishwasher. We have a septic tank. Both toilets flush fine, and no back up in tub
The drain leaving the laundry room going to the main needs to be cleaned. The first thing you can try is what is called a product called Drain King . This is connected to a garden hose and inserted into a drain where the p-trap is removed from the wall When the garden hose is turned on full blast it will try pushing out the clog You should hear it pulsate first slowly then more quickly as the clog is washed away.he water flowing with Finally you should hear water flowing freely. it helps to use warm water if possible. If that won't work the drain will need to be snaked , Turn off the hose and remove the Drain King by loosening the hose connection Then follow that pipe downhill toward the main drain, and look for a clean-out plug. You can loosen the plug SLOWLY, have a bucket, mop, and rags ready and wear old clothes. Place the bucket under the clean-out plug if possible while slowly removing it Water will come out unless the clog is between the laundry sink and the clean-out. If water comes out when the clean-out plug is removed place your snake drain cleaning device into the clean-out and run until the clog is cleared. then run water through it for a while to wash away any residual residue. Put everything back together and test for leaks.
Jul 30, 2014 | Home
My dishwasher was in a cycle and it tripped the power to the house. We have nailed down the problem to infact being the dishwasher. Is there a way to get rid of the water inside so I can open it because...
The best way to do this is to open up the door and remove the filter cage and any other associated filter parts, then put a garden hose into the filter compartment (Which is the lowest point in the machine) and syphon the water outside. This will get rid of 95% of the water. You might want to throw a couple of buckets of clean water into the machine when it gets close to being emptied, so the clean water flushes the diorty water out and you don't get it smelling after a day or two.
Tricks for syphoning:
Start with a garden hose FULL of clean water by putting the end of the garden hose into the machine and turning the hose on. Now the hose is primed, simply disconnect the other end from the tap and get it lower than the dishwasher and the water will syphon away without any of that silly sucking on the hose and risking a mouthful of dirty water.
Additionally, if you're having a problem finding somewhere lower than the dishwasher,take the end taht was on the tap outside and lift a drain cover, drop the end of the hose down into the drain, this will be lower than the washer and the syphon will start.
Aug 01, 2011 | Dishwashers
My bosh washer will not start..I cannot open the door to re-set . I turned off the power to re-set and it did not help
Hi, there maybe water left in the machine? if this is the case you could have a faulty pump or control panel.
Take a bucket and disconnect or take out the drain hose from wherever it is located, put the end in the bucket and lower the pipe to below the drum level get it as low and flat as you can so gravity drains the water that might be left in the machine, when all the water is out , put the drain hose back or reconnect it. swith on the machine and try to open the door, you may have to wait a couple of minutes, hopefully the door will open and you can get out you washing, after this switch off the machine and check the filter for blockages, clean out what ever debris there may be then re-insert the filter and try the machine on a cycle, if it stops again and doesn't drain the water then suspect the pump is faulty.
If you are unable to replace the pump then you'll have to call in an engineer to sort it out, unless it's still under warranty in which case contact your supplier or the manufacturer.
Hope this helps.
Feb 12, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Water will not drain cannot open door
The possible problems here are blockages or pump failure. Blockages are the more likely explanation but pumps can fail. If the washing machine will not empty the water out you may also not be able to open the door on some washing machines although these days it's much rarer to have a pneumatic lock on the door due to cost cutting (if a washing machine has a pneumatic door safety lock a rubber hose is connected to the door interlock from the pressure chamber bottle on the tub - water in the tub forces air up this tube and locks the door, which is released when the water is pumped out and the air pressure drops).
Some washing machines have a filter at the front of the machine that can be checked for blockages. Sometimes the filter is hidden behind a removable trim or panel at the base of the front panel. If your washing machine has a water pump filter and a filter drain hose you should be able to drain the water from the washing machine into a bowl without moving the washing machine. Open the pump filter flap and pull the small drain hose forward. Take the bung out and drain into a bowl. It's likely to be painstakingly slow but at least you don't have to try and pull out a heavy washing machine full of washing and water.
If your washing machine doesn't have a pump filter, or it has a pump filter but no draining hose then it's a bit trickier. To drain the washing machine, you will need to remove the drain hose from the drain pipe at the back of the washing machine, and lower it into a bowl or bucket. Many plumbers now plumb the drain hose into the U bend directly under the sink instead of a separate waste pipe at the back of the washer. If yours is connected directly to the u-bend, you can usually unscrew it easily. Remember though, that with the pipe disconnected from the U bend, any water poured down the sink will flood out into the cupboard until the hose is reconnected.
Once you have drained the water, you need to check for blockages in the pump by unscrewing the pump filter. If none is found, sometimes a blockage can occur in the plastic connector that the drain hose is connected to at the sink end (if connected this way)
Once you have the drain hose disconnected and lowered into a bowl or bucket the water should siphon out as long as the pipe is low enough. You are likely to get several bowls full of water from the washing machine. If little or no water comes out then it may be blocked by an item of clothing like a sock and it won't be possible to empty the machine this way or it is going to be a long process.
Once the last bit of water has drained out, the washing machine may now spin as the safety system for preventing a spin while water is in the machine will now recognize the water has gone and allow a spin. Keep the pipe low down and in the bowl or bucket and put the washing machine on a spin only program. Note, this last step is not strictly necessary as once drained, the door should open. However, you might prefer to try to spin a few more bowls of water out.
Clearly if you put more water into the machine it is likely to fail again until the fault is rectified but these instructions should at least get the clothes out.
Other possible obstructions could be inside the sump hose leading to the water pump. Many Hotpoint washing machines have a filter inside the sump hose which gets blocked. Finally, the pump itself can be faulty.
Dec 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
A1400WD has not emptied and has flashing lights and on/off flashing rapidly. The machine was set on a hot wash for cleaning. Water left in the machine up to the bottom of the door and I cannot open the...
Get some buckets
Take the drain hose off the back of the machine, undo any clips so that it lays it down flat
Put the end into a bucket and the machine will drain off.
When water has stopped running switch off the machine leave it for a few minutes and then put it into a spin cycle
Leave the hose in an empty bucket
That will dry the clothes and relaese the dorr
Your next problem is getting the obstruction out of the drain pump
For that you need a man that can
Oct 20, 2009 | Washing Machines
Whirlpool dehumidifier drains into the bucket, not the garden hos
I had a sililiar problem. I think I tightened tthe hose after putting a new rubber gasket on hose fitting, Also checked angle of hose.
Jul 26, 2009 | Maytag M7DH45B2A Dehumidifier
My washer dryer won't drain, is there a drain dial setting? there is a small amount of water that won't drain away. it means the door lock won't release
the problem is either your pump or your hoses. this an easy fix. all you need is a screwdriver and a bucket to catch water. 1st unplug the machine and remove the drain hose from the drain. then try to drain the water from the washer by plugging it back in and setting the washer to drain. if no water comes out of your drain hose then you know your plumbing is ok. next put the drain hose back in the drain and take the cabinet of your washer. you will see your pump with 2 hoses connecting to it. one hose connects to the basket and the other to the drain. disconnect the hose coming from the basket and if water comes out then you know the basket is not blocked with any article of clothing. if both check out ok your problem would be the pump
Apr 21, 2009 | Washing Machines
My washing machine is not draining the water properly,so when i do a wash, the clothes inside after its finished are still soaking wet and then i have to manually drain the water from the clothes. I have...
  • That the outlet hose is not kinked or raised more than 40° from the floor.
  • If you wish to remove articles when the water will not pump out, place the end of the drain hose into a bucket on the floor and allow water to drain out by gravity, noting that more than one bucketful may be present. Hook the hose into the sink again and try the spinner before removing the articles - if this fails most of the water can be baled out with a cup.
  • If the above method fails to remove the water then the pump is probably blocked - do not open the door, but contact your nearest Service Engineer.
  • Thanks for using Fixya!
    Aug 26, 2008 | LG Washing Machines
    Washing Machines Logo
    26 people viewed this question
    Top Washing Machines Experts
