Question about Jenn-Air JES9800A Electric Kitchen Range
Jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
I have a jenn-air jes9800AAB electric slide in range. It just started buzzing and the front light panel flashes on and off then stops. none of the controls on the touch pad will work now. Also when it stops buzzing the oven interior oven light comes on. then the oven light will go off and it will start buzzing again. the buzzing sound is coming from the touch pad area.
Any help is greatly appreciated,
Tom, Indiana
  • Anonymous Mar 28, 2014
    oven panel shows f9
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Posted on May 30, 2008
SOURCE:
Jenn air slide in electric kitchen range when press any button on key pad message says feature not available
Try turning the breaker off to the unit for an hour and then try to use it again. Keep me posted.
Apr 05, 2013 | Jenn-Air SVE47100 Slide-In Electric...
Front left burner doesn't work on our jes9800aab
This is your infinite switch. It just went out and you can replace it very easily. Just give us a call or email us and we'll be sure to get the right switch out to you right away to get you cooking agin soon. We hope to hear back from you real soon. Hope this helps you!
Aug 16, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Jul 03, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Older jenn-air stove
on the front panel does it have a button that says CLOCK if so press that then with + button see if setting changes if so when it gets to the correct time stop and press clock again .
Oct 25, 2017 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Beeping noise - letters appear fc
Since Jenn-Airs codes are F1-F9, the cicuit board may be on the way out since the code resets after you turn it off for a while.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Jennair cook top
Replacing this top is not too difficult. It is secured by four screws on each side. You might have to remove some of the flanging in the back to pull it off. Make sure to unplug the the unit. I would think that the top might be pricy, but if you take your time replacing it should be no problem.
May 02, 2006 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air JES9800A Electric Kitchen Range Logo
679 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
