Colors seperating. 6 inches in both sides of screen's color are seperating, like a ghost image. and I can't seem to get into the service menu, can you give me step by step instructions to do this.
  • 8,617 Answers
What make and model TV do you have? Each one is different to gain service menu.
Posted on Jan 14, 2008
My 53UWX10B has a picture problem. Picture is blue and yellow and the yellow is offset to one side a couple of inches. Gives a "ghost" image.
If the picture is 3d looking in some way----it is a convergence problem; many of these sets have "magic focus" and if it will not correct the problem the two convergence chips need to be replaced---this model should use either STK-392-110 OR -150 CHIPS.
This can be a do it yourself repair if you have some skill and total parts cost on Ebay would be under 25 dollars.
Let me know your skill level here and I will instruct you how to do the fix.
SD TECH
Aug 04, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Color ghosing images
The convergence ICs have failed
Jun 19, 2009 | Televison & Video
Background ghost like images
CHECK IT IN THE DIFFERENT ASPECT MODES. IF THE IMAGE STAYS IN THE SAME PLACE REGARDLESS OF ASPECT. THEN YOU HAVE A LCD PANEL PROBLEM. PANEL WILL HAVE TO BE REPLACED.
Feb 27, 2009 | Televison & Video
Watching TV and top 1/3 screen ghosted by colors
on this type of tv each gun is controled by hor.and ver. chip together. it is on the board that controls the convergence of the tv. some manufactors have recalls on problems like this. i dont know if this one does but it may. you can check with mitsub. i do know that this part is about 250.00
Jan 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Skt IC and Capicitor??
You need to replace both STKs. They are pretty obvious to find in the unit. They are normally mounted to the same heat sink and will typically be about 3 inches long each, maybe 2 or so high...Front should read something like STK350-120
Feb 07, 2007 | Panasonic PT-61HX40 61" Rear Projection...
AKAI PT5598HD
Your set has what is know as "convergence problem" because of the bowed lines and ghost in different colors,is really not an easy solution,the set should have 3 amplifiers(one for each color)and they need to be replaced with an exact replacement,sometimes just by replacing them the aligment should be close but soemtimes you nned to get into the service menu to do some adjustments,the amps(IC's) are mounted on heat sinks and all 3 have the same part number on its face,they normally read STK--- ---,every set uses different amps,If you are familiar with tv service you have now a place to start working but if you are not too familiar be safe and call for help from a servicer.Let Us know if you need more information.
Oct 31, 2006 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
