Question about Toshiba 42HP95 Television
Toshiba TV "NOW BOOTING"
Im looking to pick up a toshiba 42HP95. it doesnt work however. i was told it will power on and display "now booting" and then shuts off after a few minutes.
SOURCE: Toshiba 20vl14 power loss
Mine does the same thing!!
Posted on Apr 26, 2008
kakee
  • 1269 Answers
SOURCE: Firmware update
I apologize I already forgot what your main concern was. Can you please resend my solution that I gave to you? Sorry for the inconvenience
Posted on Aug 23, 2008
SOURCE: Blinking RED power Light 42hp95 Toshiba
I have done some research because I have the same problem and this is what I have found. Hope this helps.
These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This is why the power light blinks. This model of TV has over 2,000 parts which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad. This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced. The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
I will expect the repair will be $250 to $350. A small TV shop will often charge less than a large repair facility. I believe the TV will be worth having repaired even though a LCD TV will cost less to operate.
Posted on Oct 19, 2008
  • 5 Answers
I turned the 42HP95 TV off one night and it didn't come back on. Had the red LED flashing etc. Found the solution posted by CheapTech: http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back but didn't take it seriously because these things never work, others were mocking the answer blah blah. Well, just before kicking the damn thing to the curb, I grabbed a screwdriver, took off the back cover, unplugged the little do-hicky sugested in the Solution, and the idiot box came right back on. Go figure. Been working ever since. SO, you might want to try this before busting out the electrical schematics and dropping $$ on repair. Cheers.
Posted on Feb 20, 2009
SOURCE: Toshiba 42HP95 Plasma tv
toshiba plasma 42hp95 tv will not turn on red led lights blinking
Posted on Feb 23, 2009
Tip
Toshiba 42HP95 VChip Reset
Toshiba 42HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Parental V-Chip parental lock?
Have you forgotten your VChip PIN, passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The VChip passcode will be reset and you can enter a new passcode if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
TOSHIBA MODEL #42HP95-BLINKING RED POWER LIGHT WONT STOP
Ur power inverter board is dead.
U need a new board.
Sep 07, 2009 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Front Panel Lock Reset
Toshiba 42HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Front Panel Lock?
Have you forgotten your Front Panel Lock PIN, passcode or password?
If you forget your Front Panel Lock passcode, you can unlock the front panel without entering your password:
  • The Front Panel Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Input Lock Reset
Toshiba 42HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Input Lock?
Have you forgotten your Input Lock PIN, passcode or password?
If you forget your Input Lock passcode, you can view the locked input without entering your password:
  • The Input Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
Worked for me, was ez, and I am a huge skeptic and not very "TV technical."
Dec 23, 2008 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
Tip
I hope that helps.
Tip
Toshiba 42HP95 Manual Download
Would you like to review the features of the Toshiba 42HP95 Plasma TV ?
Have you lost your Toshiba 42HP95 Plasma TV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 42HP95 Plasma TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 42HP95 Plasma TV documentation.
I hope that helps.
___________________________________________
Tip
I hope that helps.
Televison & Video Logo
234 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
