Question about HP LaserJet 1010 Printer
HP 1010 Printing fine, then suddenly just stopped. Enough ink, paper properly inserted, command going from PC fine. I can hear one of the rollers turning strangely, but find it hard to believe a mechanical fault could have come on so suddenly without any seeming cause! Suggestions much appreciated :).
    Problem Solver:
  • 9 Answers
Ppls. remove the cartridge and close the cartridge door hear the sound if it is not comming then change the cartridge and then check
if ur problem solve pls. remarks ur word
Posted on Jan 30, 2008
All the lights are on in hp laserjet 1010 printer i cannot print any page how to solve this problem
Try a hard reset of printer and/or reinstall the software, Check cartridges for ink and operation.
Sep 04, 2016 | HP LaserJet 1010 Printer
My hp laserjet 1010 does pull the paper for printing.
You mean its not pulling the paper inside?, clean the pickup roller surface, if surface found smooth replace it..images?q=tbn:and9gcstypfi_zq1adkso1rrfxtsomle0sez8vlfd0wovmccd7tyhxn3m4rwtamr
Oct 06, 2011 | HP LaserJet 1010 Printer
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
My HP Officejet J3680 has stopped printing. Ink
Hello sir; Could be memory getting bad, not worthy to repaire, rather go buy a new one instead bring to the shop for fix it.
Nov 28, 2009 | Computers & Internet
It does not print
my printer hp 1010 was printing fine and suddenly stop print pages.it take in page and through it out as blank page.
Jul 02, 2009 | HP LaserJet 1010 Printer
Paper stuck
open the flap at the output section, take out the toner or ink cartridge, then pull out the paper.
May 30, 2009 | HP LaserJet 1010 Printer
Black not printing properly
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer........
Good Luck
May 07, 2009 | HP PSC 1210 All-In-One InkJet Printer
Paper jam problam
no the tefflon is not fitted properly as you again open the printer and clean the tefflons upper side as any of the greece substance is got stuck up on the tefflon to cause this problem.also clean the pressor roller of orange/red colour with the isoprophyl and then slowly rub the liquid with very dry tissue.your pressure roller is perfectly alright as this paper jam problem comes very often after the tefflon is changed if it is not fitted and cleaned properly.
Jul 02, 2008 | HP LaserJet 1010 Printer
Printing Business Cards on Cardstock
It could be.
Part of the problem with that machine is that it has to bend the paper to get to the inkjets. If its too think it will stop running.
We use this Avery stock for printing business cards that might be a little thinner cardstock. I would look for some recommended for ink jet printers.
Jun 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer jam
open top cover of your printer and put a couple of drops of 3 in 1 oil on the carrige bar ( THE BIG SILVER BAR THE INK CARTRIDGES RIDE ON)
THEN CLEAN ALL THE RUBBER FEED ROLLERS WITH A MICROFIBER TOWEL MOISTENED WITH ISOPROPANOL ALCOHOL THEN TRY THE PRINTER AGAIN
Jan 11, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP LaserJet 1010 Printer Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
