Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
HD65W20JX1 RCA SCENIUM THOMPSON MULTIMEDIA
TV TURNES ON FOR 10 SECONDS WITH NO VIDEO AND AUDIO BUT YOU HEAR THE SPEAKERS MAKE A POPING SOUND
  • Ronxxx Jun 01, 2008
    Will not power on. Is there a fuse?
Yep i had same bought seconhand off ebay repaired in ten minutes its the transistor situated on power board directly at back of high tension coil cost approx £1.90 easy fix
Posted on Oct 22, 2008
    Problem Solver:
  • 4 Answers
Did you get this figd out i can help if not
Posted on Feb 24, 2008
Looking for an owners manual for the D52w20 RCA 52 Rear Projection TV.
kimmipoo_2000@yahoo.com
Posted on Jan 18, 2008
There's a buzzing sound coming from our RCA Scenium tv, how do we fix it?
Are you using RCA type audio cables?, if so, make sure the connectors are tight and the cables are not frayed, it also helps routing those analog cables at least 8 inches away from any power cords or transformers. Buzzing usually is caused by loose ground connections or RF interference.
HDalacarte.com guy, audio/video/computer technician for over 30 years
May 26, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
Good morning. I want to get an idea on how to connect my Panasonic lcd TCL32X1X to my Bose Sound System. What I want is to hear tv programs thru the Bose speakers.
TV's are video OUTPUT devices, not sound INPUT devices.
Get the TV-related audio into the Bose directly from the digital audio output of the same source from which the TV is getting the video. You can also run a mid-fi RCA analog stereo feed to the TV (if it has speakers) so you can watch and listen to stuff without the Bose turned on.
Jun 28, 2010 | Audio Players & Recorders
Cant hook it up to the tv and make sound on speakers
There are a couple of things going on here.
First concept: The physical TV is NOT a good source of audio or video. It's there to turn audio and video from other sources into something your senses can enjoy. Many TV's (monitors) don't even have speakers.
You probably want the TV-related audio to play on your Sony. Your best source is to get it where it comes from. That is NOT the TV, more likely cable or satellite. Draw the best multi-channel audio (digital, if available) from it into the compatible input on the Sony.
The cable box will also have video and analog stereo audio. Run the BEST VIDEO (HDMI or component) to the TV's video and the analog stereo RCA Audio Out to the TV's Audio In so you can watch and hear cable without the Sony if you like.
You could also run the TV's analog Audio Out RCA pair into an AUX input of the Sony, but that would limit whatever you hear to stereo and any audio limitations of the TV.
Mar 11, 2010 | Aiwa AV-D67 Receiver
I have no audio on my RCA Scenium rear projection
Replace Audio output ic. Make sure you do not have sound turned off.
Sep 28, 2009 | RCA Televison & Video
VIDEO 1 AND VIDEO 2 DON'T WORK WITH SATELLITE. VHF WORKS BUT NO SOUND
First of all check if theSatellite box or the RCA cable is working ok with other equipment/TV if they both r working fine then their is an internal problem with ur TV.Show it to a authorised service person.
Jun 01, 2009 | Televison & Video
RCA Scenium
Sounds like a cold solder joint in the power supply or faulty capacitors.
Mar 11, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Sound off my tv
Hello tennie,
Check your audio out configurations on your TV menu, this includes mute and volume control. After checking them, then try to see if any audio is coming out of the other audio outputs. If there is, then you may have damaged speakers. If there is no audio on any of the outputs you may have a damaged audio output processor or a poor connection in the audio section. If this is an audio circuitry issue; I would suggest that you take the unit to a TV repair shop for an estimate, and let them repair it.
I hope this helps,
Thank you,
Shuttle83
Feb 19, 2008 | RCA D52W136D 52 in. TV/DVD Combo
"weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
265 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
