Question about Motorola T5000 Two Pack 2-Way Radios with 5 Mile Range
Motorola T5000 Rx problem
I have a T5000 that can't receive but can transmit. Is there any schematic diagram for the PCB that I can refer to or what can I do to restore the problem.
Thanks in advance
  • Peter Timbol Jan 14, 2008
    The speaker is ok because it has all the beeps and sounds.
    I had already sprayed contact cleaner on the volume control.
    Am also transmitting from 2 other T5000 radios. This unit just stopped receiving two days ago.
    Your last suggestion is what I actually feared, and it seems to be that is the problem. Am in need of a schematic diagram of the board so I can test which part I can replace if possible (I have other busted T5000s lying around). I just need this as a back-up radio. The bosses are taking forever to approve my request for new ones.
  • Peter Timbol Jan 16, 2008
    This doesn't have squelch control since it is just a Talkabout radio. Am usually in the Raon area but the bosses don't want to spend money for repairs because they classify this as disposable stuff. Am just repairing it as a back-up.
    If it is the YD3361 chip, then this unit basically is junk. Will just take the PTT and transfer it to another unit that is working but with a busted PTT.
    Thanks,
    Brigadier General:
  • 6,966 Answers
Hi SirDrag,
Your concern could be the internal speaker of the T5000. This could be verified by attaching an external speaker or a headset compatible with the unit through its accessory jack. Should this be the case, it of course would require replacement. Though Motorola speaker for this model is proprietary in design, those made for Alinco, Icom, Kenwood and/or Yaesu should also work. The only concern would be getting one that will fit the physical mounting limitations of the front cover.
In some instances, it could be the volume control developing blind spots along its carbon pad. A spray from an electronic contact cleaner should do the job (albeit temporary).
It is also possible that the Interference Eliminator Code setting is different with that of the TX radio.
Worst case possibility is a defective electronic component (such as the op amp) which would then require the professional services of a qualified communications technician.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 14, 2008
  • Louie  Role
    Louie Role Jan 15, 2008
    Copy, if at all possible, have you tried using the radio without the Interference Eliminator Code or Carrier Squelch set at 0?
    Since the beep works, chances are the audio amp is OK leaving us with only the auto muting (code activated) and/or the if/demodulator stage.
    I will not include the RF stages since I am assuming that you have tested its reception with the TX radio pretty close to the non RXing radio.
    Just to share, my experiences with similar faults on other models of Motorolas usually centers around:
    crystal filter - normally blue or yellow/orange in color with 3 terminals
    IF/Squelch IC - MC336? - usually underneath the logic/display board
    Tone en/decoder IC.
    If you're anywhere near Gonzalo Puyat (formerly Raon), there are a couple of establishments accepting Motorola repairs.
How do I get the Motorola T5000 and Boafeng UV-8D radios to communicate with each other?
check you settings in the radio,follow your instruction manual for the radio
Jun 11, 2015 | Motorola TalkAbout T5000 2-Way Radio
What is the AC adapter specs on the charger for the T5000
No polarity. The adaptor puts out AC , low voltage. Just traced the schematic and found out.
May 04, 2013 | Motorola TalkAbout T5000 2-Way Radio
Cannot receive or transmit
A few items to check:
Be certain both radios are set to the same:
Frequency
Qt filter
For a simple test set the Code, Qt filter, and any other special features to off or zero. This will allow you to find out if the radios will work simply on their frequency. Once you establish this, you can add in the features as you need them.
Here is a link to the T4900 & T5100 user guides (couldn't find T5000 alone.):
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4800_UserGuide.pdf
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXx_User_Manual_E.pdf
Best regards.
Jun 26, 2012 | Motorola TalkAbout T5000 2-Way Radio
I have two motorola aux4100 radios. I can not get them receive. When I key it up to transmit, the red LED of the transmitting unit comes on and the green LED on the receiving unit comes on but does not...
I would guess you have a PL set on the receive side, and not on the Transmit side. So the audio is being blocked by the PL (as it is supposed to be!) Check your programming, make sure you have the same PL on tx and rx.
Jun 03, 2011 | Motorola AUX4100 2-Way Radio
I have 2 Motorola T5000s and 1 T4500 that came together in a set years ago. The two T5000s seem to connect to each other fine, and the T4500 receives messages and signals from the T5000, but does not seem...
Here's a link to the user guides:
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXX_User_Manual_E.pdf
http://www.giantintl.com/ContentManage/manuals/Moto/T4500_User_Manual_E.pdf
Check your interference eliminator code (aka PL, private line, or code). It is likely set to zero (off) on the T5000s and set to a different number on the T4500s. They must match to work together. Otherwise the one with code turned on will not recognize the other one.
Best regards.
Jan 27, 2011 | Motorola Talkabout T4500 (7 Channels)...
Rx not working
You need to check the programming of your Frequency, interference Code eliminator and Qt filter, if any. All must match one another for the radios to communicate. You have posted under the T5000 heading, here is a link to the nearest numbered user guide. http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XxX_User_Manual_E.pdf
Best regards.
Nov 30, 2009 | Motorola T5000 Two Pack 2-Way Radios with...
Could be due to air blowing the mic or something but please remember that usually transmissions are fuzzy,
Sep 27, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola t5000 charger polarity
The Polarity of Motorola's equipment is always Center Positive.
Pat
Aug 13, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
One of he units will not transfer
Looks you have a TX prob, either the TX switch is faulty or the PCB has gone bad.
Dec 15, 2007 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola t5000
If you have already checked both radios have the same code and channel both radios must reicive and transmit between each other check if you have any QT in any display this is a third condition to reicive.
Jun 06, 2007 | Motorola TalkAbout T5000 2-Way Radio
Motorola T5000 Two Pack 2-Way Radios with 5 Mile Range Logo
347 people viewed this question
Top Motorola Radio Communications Experts
Steve
Jose Ma DM.
Jose Ma DM.
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
