Question about Technics SA-DX850 Receiver
F70 I have this problem with my Technics SA-DX 850 receiver. When I turn it on it works for 30, 40 seconds and then it shows a message "F70, switch off the power". Any ideas how to solve this? Thx! Cato
  • Catic Jan 14, 2008
    No, I definitely don't push it. Thx though!
  • jantie May 18, 2008
    Same fault, sometimes F70 on display, after few times restart, works again
  • 979 Answers
The system has detected a fault in the output section. How much are you asking of the system? Greater than 50%? That will push most systems to their limit in a short period of time...accordianman
Posted on Jan 14, 2008
  • hopeton clarke
    hopeton clarke Aug 12, 2013
    i remove my 2 outputs and it still showing
The internal fuse might be blown change the fuse and see if that will help
Posted on Jun 13, 2008
Technics sa-dx 950 Intermittent F70 Error
There should be removable access panels under the amplifier IC's that are attached to the heatsink. Remove these panels and inspect the solder connections on the IC's and the voltage regulators that should be mounted next to them. These have always had a tendency to go bad on Technics receivers. If you resolder all of these, you should clear up your problem.
Feb 26, 2015 | Technics Audio Players & Recorders
SA-DX750 error F70
I have a technics sa dx 750 receiver that cut...
Dec 21, 2010 | Technics SA-DX750 Receiver
System overload (technics sa dx-850)
audio amplifier IC damaged need to be replaced
Sep 25, 2010 | Technics SA-DX850 Receiver
Technics sa-dx 950. F70 on display. ???
This is a shorthand version of protect. See the link below. If you have more questions, please post them here and I'll respond.
Aug 21, 2010 | Technics SA-DX950 Receiver
Problem with Technics SA-DX850
SA-DX750 (sister Model to SA-DX850). Showing error code F70, after a few minutes running. Checking the power rails revealed +5VA and +5VD, on the Digital Circuit Board 'A', dropping to about 2V, when fault occured. F5, T1A, on the Sub-Transformer Circuit 'M', was subject to occasional blowing. The problem was traced to an intermittent break, in the printed circuit board conductor, in the vicinity of Q1702 (+5VD regulator) collector, on the Digital Circuit Board 'A'.. Repairing this cured the problem. Note that removing F5 (above), or disconnecting CN702, CN1000A or CN904B, on the Digital Circuit board 'A', also causes this error code to be displayed. Failure of the audio output ICs, IC651 & IC801, is apparently the usual reason for this error code being dsiplayed, but it is worth checking the power rails viz. +/- 25V (Fuses F3 & F4, T6.3A, on Sub-Transformer Circuit 'M') +/- 55V, +/- 14V etc.
Aug 11, 2009 | Technics SA-DX850 Receiver
F70 on my reciever
Most likley it is in need of repair. I suspect the output IC. Check for bad solder connections on the IC and voltage regulators.
Remove the speakers and see if it still happens (it probably will).
Feb 11, 2009 | Technics SA-DX940
Technics sadx750 and says f70 and turn power off
Feb 27, 2008 | Technics SA-DX750 Receiver
Could anybody tell me what F70 means ?
You must have air flow through this unit!...accordianman
Dec 04, 2007 | Technics SA-DX850 Receiver
What is F70???
F70 means Blown Internal Fuse change the internal fuse and that should solve the problem if not you may have to change the output
Oct 30, 2007 | Technics SA-DX750 Receiver
Technics SA-DX950
when turn on receiver , after few seconds got message
F70. when wants to do any operation with receiver got message SWITCH POWER OFF
Jun 25, 2007 | Technics SA-DX950 Receiver
Technics SA-DX850 Receiver Logo
1,308 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
