Question about 3Com SuperStack 3 3824 (3cr17402-91-uk) 44x1000 Mbps Networking Switch
3Com 3824 Hi , I'm having problem connecting to my 3com 3824 using window vista. the method i use to connect via command prompt using telnet it prompt me "could not open connection to the host , on port23 : Connect failed. Please help
Download free version of HyperTerminal for Vista :
Make a new connection :
connect using COM1 (depends of your configuration)
19 200 bits/sec
8 data bits
No parity
1 stop bit
No control of flux
And push enter twice to display a "Login:" prompt.
Connect using default user/passwords :
Posted on Jun 26, 2009
Try 3com network supervisor software. Or try Hyper terminal from windows
Posted on Mar 07, 2008
  • 407 Answers
You setup your network enabil.......... new setup conect port.....
Posted on Jan 28, 2008
3com don't telnet
Make sure its not blocked from the router settings and the corresponding port is open.
Sep 24, 2013 | 3Com Computers & Internet
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Dear Vendor, I have a problem related to connecting to the login to the 3COM Switch 4500 26-ports. I am currently using computer Laptop model Acer Spire 4935, and my computer has no serial port. So,...
You can log into a Switch 4500G Ethernet switch in one of the following ways: ? Log in locally through the Console port ? Telnet locally or remotely to an Ethernet port ? Telnet to the Console port using a modem ? Log into the Web-based network management system ? Log in through NMS (network management station)
Dec 29, 2017 | 3Com Switch 4500 PWR 26-Port...
Connecting a 3Com 2952 Plus switch to a Cisco 3750 switch
If you also have a standard copper cable (or a second fibre cable) connecting the two switches (for resilience perhaps?), this issue is probably being caused by something called Spanning Tree. This is implemented on switches as a 'loop avoidance' system, and can look like you have described with one end 'ip' and the other end no lights.
On the Cisco switch, get to a telnet/ssh/console session, log in and enter show spanning-tree and press enter.
have a look to see if the fibre interface has a status (sts column) of BLK. If it has, then this is called 'blocking' and will remain like that until you remove the second link to the other switch.
Hope that this has helped!
Mar 03, 2010 | 3Com 3CSFP91 Transceiver
How can configure trunk
not sure about the 3COM side, but on the Cisco side... go to the configure prompt, then the port that you need to trunk (int [interface name and number] and enter)
Once you are in the interface, use the following command:
switchport trunk encap dot1q
switchport mode trunk
Then make sure that the interface is not shut down, connect the switches together and (hopefully) the 3COM will negotiate to trunking... if not you will need to manually configure the 3com.
Hope that this helps!
Jan 07, 2010 | 3Com Switch 4500 PWR 26-Port...
How can i access it using telnet?
if it allows telnet sessions, you would go to a command prompt and type:
telnet (or whatever the IP address of the switch is.)
Jun 23, 2009 | 3Com 4500 24-Port Ethernet Switch
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
How to connect wire less connection with my laptop,
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
Aug 11, 2008 | Linksys WRT300N Wireless Router
Can't access 3Com OfficeConnect Router browser
you go to start, run, type cmd. and then type ipconfig. locate the ip for default gate way. Use the ip to go to your browser.
Aug 10, 2008 | 3Com OfficeConnect Router
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Jul 25, 2008 | 3Com 4500 24-Port Ethernet Switch
3Com SuperStack 3 3824 (3cr17402-91-uk) 44x1000 Mbps Networking Switch Logo
1,324 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
