Question about Wang 5525ES QIC Tape Drive
I hade tabe drive installed on machine but didn`t apper on my computer
0 characters
1 Points
Ho do i fix if my acer aspire 4333 usb is doesn't open in my computer
When booting up press f2 to go into bios. In there make sure usb support is activated thenstart the machine. It should now be working. If it is not hover the mouse over the computer icon , or go into the system settings, enter device manager, check the status of usb there. If it has "!" in a yellow circle that means there are issues regarding it functioning.Right click on the device and check that it is not disbled. that should sort it out. If your laptop has USB3 you might need to install drivers
Jun 03, 2015 | Acer Aspire 4250 4251 4252 4253 4333 4339...
Have an old Iomega Ditto tape drive Easy 800 and Ditto Tools software for Windows and Windows 95. Want to move data from old tapes onto Vista Op Sys and then onto a CD. Will this old software install on...
Is it possible to find an old computer running an old version of Windows, and then to connect the tape-drive to that computer, and then to copy the files onto a folder on that computer?
Then, if that computer has a network-card, you can "share" that folder, so that all computers on your network can then access that "shared" folder, i.e., to copy the files, and then to burn them to a CD-recordable.
May 05, 2011 | Iomega Ditto 800 External Tape Drive...
My computer crashed, onstream driver still works. Can I install driver on new computer?
if it is compatable. try it and see
If it does not work on the new computer it will not hurt anything at all it will just reject the driver
Apr 30, 2010 | OnStream DP30 (DP30-01) ADR Tape Drive
SCSI tape drive, 150MB ARCHIVE corporattion ,2150l it is very old & i donot use it before i need help to test it for & can i used it with windows xp
To be completely honest, unless there is vital data stored on a tape drive that you absolutely must access, this technology is severely outdated and not worth the hassle of finding the appropriate drivers for Win XP. An CD burner is very very inexpensive, easy to install if there isn't one already (especially external drives). Most computer shops have used CD burners in stock and will sell them basically for pocket change.
Archive Corporation was purchased by Connor Peripherals in 1993 and they don't appear to have Win XP drivers readily available for that model. If you need to test that drive, you will need to couple it with an old computer. Try a functioning computer at a garage sale, seriously. You can probably get one for about $10 WITH a monitor! That's going to be your best bet.
I hope this helps, I know you wanted different news, but at least this is accurate.
Jan 12, 2010 | WangTek 5150ES 150MB SCSI Tape Drive Tape...
Under MY computer drive does not register
yes you will need to load the driver for that DAT drive, you will also need to load the software that will allow you to backup and or store data on the tape .
Jan 28, 2009 | IBM (59H3537) DAT Tape Drive
Tabe back up
try this shout "boo!" at the hardrive as it reads it should give you no problems after that;)
Jun 18, 2008 | LaCie (300908) AIT Tape Drive
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
Need software to run on vista 64bit
Vista has issues re drivers for older stuff The best you can do is seek out an older machine[a friends] and get the stuff off onto CD.
Jun 02, 2007 | Sony SuperStation QIC Tape Drive
Tape Drives Logo
41 people viewed this question
Top Wang Tape Drives Experts
Level 1 Expert
Jax Planet
Jax Planet
Are you a Wang Tape Drive Expert? Answer questions, earn points and help others
