Question about HP Photosmart C7180 All-In-One InkJet Printer
Paper jam We can't get to the paper jam on the Canaon I960 Had a paper jam (HPC7180). Got 90% of paper out...still pieces in there I can't get out. Tried from back door, ink change door...can't get at it. What do i do?
    Genius:
  • 1,665 Answers
It must be disassembled.
To remove the cabinet you need an asteroid screwdriver.( there are four screws in deep holes at the upper side.)
Dont do this by yourself if quaranty has not expired, or you have not some tech. experience.
Posted on Jan 14, 2008
There are pieces of paper jammed inside the printer. I cannot access them by raising the scanner. I could see a small piece but after the ink holder adjusted when I turned the machine back on, the small...
I have mine apart right now trying to fix it. I was able to get my paper jam fixed (had the same problem) by putting another piece of paper through when it tried to roll the jammed paper out.
Does that help?
Aug 13, 2011 | Epson Stylus NX400 InkJet Printer
Three yellow flashes then one green. Printer will not print. Says "check to see if plugged into computer and on." Sometimes says "paper jam" (no jam viseable.
Three flashes says that there is still paper or paper scrap inside. Might be a small scrap, hard to see, or sensor arm damaged when earlier jam removed.
Jul 29, 2009 | Canon I960 InkJet Photo Printer
Paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
Canon i850, i950, S600
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
If I could be of furtheme know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Cannon Canon i960 Photo Printer
Unplug the printer and let it set for a few minutes and plug it back it. This should reset any errors you printer has stored in its memory.
Jan 29, 2009 | HP DeskJet 932c InkJet Printer
CANON I960 BLINKING RED LIGHT 2TIMES
is the piece of paper removed? or there parts of the paper w/c was nt removed? if the whole paper was removed already, try to use this steps..step 1. remove the power cord of the printer. step 2. press the power on/off of the printer while plugging the power cord. and wait for 10 seconds before releasing the on/off button..then put on your printer. but if some pieces of broken paper inside the printer try to clear it first then try printing.
Jan 02, 2009 | Canon I960 InkJet Photo Printer
Canon MP140 paper jam error with no paper jam
try this
alternative :
Oct 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
Paper jam
If you can see it then you should be able to take it out, it's not going to be easy.
Get a long pair of skinny needle nose pliers and take it out piece by piece.
Oct 28, 2007 | Canon I960 InkJet Photo Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
82 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
