Question about Microsoft Windows Server Standard 2003 for PC
Win xp problem
I want to set up a password policy for opening files & folder how can i do it
  • Anonymous Jan 20, 2008
    how con take a server backup
How con take the server backup
Posted on Jan 20, 2008
    Genius:
  • 1,665 Answers
To edit local security settings
  1. Open win xp problem - shortcutcold.gifLocal Security Settings.
  2. Do one of the following:
    • To edit Password Policy or Account Lockout Policy, in the console tree, click Account Policies.
    • To edit an Audit Policy, User Right Assignment, or Security Options, in the console tree, click Local Policies.
  3. In the details pane, double-click the policy that you want to modify.
  4. Make the changes you want and click OK.
  5. To change other policies, repeat the two previous steps.
note.gif Notes
  • To open Local Security Policy, click Start, click Control Panel, double-click Administrative Tools, and then double-click Local Security Policy.
  • If you would like to edit the security settings for file system, registry, and system services on the local computer, you must first edit the changes in the form of a security template and then configure the computer using Security Configuration and Analysis.
Posted on Jan 14, 2008
Tip
■■■ Image in folder background...
■■■ Image in folder background ■■■ Image in folder background
~~This trick will help u in setting a pic in your folder background
Go to Control panel -> Folder options -> view tab -> show hidden files and uncheck the 2 boxes below it
Open a folder, search for a file desktop.ini (cnt find it? scroll to end of this post)
U will see something like this or a bit different
[.ShellClassInfo]
IconFile=%SystemRoot%\system32\SHELL32.dll
IconIndex=3
Now add this line below it:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
IconArea_Image=C:\Documents and Settings\win xp\My Documents\My Pictures\kihlo32qwe.jpg
Change
with ur location of the image u wanna set as background
Refresh and close the folder and chck again
on Dec 14, 2009 | Computers & Internet
How do I change from two click operation to one click
Hi. If your using Windows look in Controll Panel -Folder Options. You should find an option to single click to open files.
Jun 19, 2011 | Computers & Internet
Cant call out or in off of ny black berry 8520
Go to your Options : Security >> Security Options (the same page where you can enable/disable passwords) & scroll to the bottom. If there's an IT policy attached, it will be mentioned there. Remove the IT policy using these instructions
Procedure
Step 1 : Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here.
Step 2 : Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry).
Step 3 : Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest OS for your device. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts.
Step 4 : Close the Desktop Manager if it is open.
Step 5 : From the Windows XP Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to:
HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager
Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to:
C:\Program Files\Research In Motion\BlackBerry\policy.bin
Step 6 : Open the Desktop Manager.
Step 7 : Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications.
Jan 04, 2011 | Cell Phones
Hi, I have two pc running with windows xp operating system. From User 1 i need to access user 2 windows folder and program files folder otherway around also but I can't how? Even if I shared windows folder...
First thing Windows XP Home Edition will give you numerous problems when sharing files, you should consider using windows XP Pro for that sort of operations.
Assuming you have Windows XP Pro installed in both computers:
1 - Create the same user on both computers ( same account name, same password ) blank passwords are not allow between file sharing as per windows xp group policy.
2 - Create a resource to share ( example: C:\)
3 - Disable simple file sharing
* go to control panel
* click on folder options
* click the VIEW tab
* unckeck the use sharing wizard
4 - Make sure that the user that will be used for authenticating between computers have the proper NTFS permissions and the proper access to the shared sources.
5 - Try to connect to the shared sources when asked for username and password type the credentials of the newly created user.
Now you should be able to connect to the shared sources both ways.
Oct 18, 2010 | Computers & Internet
In my att blackberry it says error 507 how do yu fix that
To solve Error 507 You need to update/ReInstall the BlackBerry Operating System.
With error 507 appeared on display, during update sw ask device password,just type any password what you like 123456789..
how to reset blackberry password ?
Enter wrong password 10 times your device will deletes all your device data & reset user password
Note : If you type your BlackBerry® device password incorrectly , you might be prompted to type blackberry before you can continue.
you need to remove IT policy , here is the working solution how to remove IT policy tested by me many times
Procedure
Nov 24, 2009 | Cell Phones
Forgot administrator's password
Hi Reggie,
Please read the entire article before proceeding:
All administrator accounts are created equal, with equal
powers, except that the main adiminstrator account cannot
be deleted and it does not appear on the login (or users)
menu by default.
You do need an alternate administrator account to solve this
problem. You must login to a user account with administrative
privileges in order to access system resources, take ownership
of files and folders, and to change other people's passwords.
(including the built-in administrator account)
Otherwise, what would be the point of any security at all,
if you could bypass it at will.
If you can login to another account with administrator pri'vs,
then follow me. Otherwise you may have to pursue more difficult
options, as explained later.
1) Open up the control panel
2) Open up Administrative tools
3) Open up local security settings
4) Expand Local policies in the LHS folder tree
Check:
Accounts: Administrator Account Status = Enabled
Accounts: Rename Administrator Account = Administrator
this is to make sure that the admin account is enabled,
and has not been renamed. You can double click on these
settings to change them. Is you are for some reason unable
to enable the admin account, you must reboot to safe mode,
where the admin account is always enabled.
Now that you are sure that you have a functioning administrator
account, you must reset the password, since you cannot
retrieve it:
From the control panel, once again open up
Administrative Tools ---->
Computer Management --->
Local users and Groups ---->
Users ----->
Administrator ---->
Right click on administrator ---->
SET PASSWORD
This should do it.
N.B.
The administrator account will be re-created, you will loose
1) All settings and preferences
2) Access to any NTFS encrypted files the administrator
has encrypted.
3) Stored network and internet passwords (the administrator's)
4) Personal security certificates.
This procedure is different from simply changing the password,
because you don't know the original, so Windows treats it as a
hostile takeover, That's why you loose access to encrypted files.
If you have trouble starting the computer management Applet,
Run it manually:
START --> RUN --> compmgmt.msc
or
...\WINDOWS\system32\mmc.exe compmgmt.msc
Trick:
If you do not have access to an existing account
with administrative privileges, you may be able to hack in
with and old setup disk from Windows 2000, with
no service packs, or at most XP1
The reason is that Windows 2000 did not anticipate nor
respect Windows XP security.
1) Reboot from the 2000 disk, and follow the on screen
prompts to repair the system using the
SYSTEM RECOVERY CONSOLE.
2) Do not proceed to install Win 2000, make sure you
get out before it asks you to format a disk, if you get
there you missed the prompt and you have gone too far,
Reboot and try again.
3) Once you are in the recovery console = DOS like environment
type HELP, and it will give you a list of commands.
You should be able to create a new user account
(with admin or change the admin password privs)
4) The last alternative is to purchase an XP password recovery
utility, which you run from a boot CD.
Good luck
Martin.
Apr 23, 2008 | Microsoft Windows XP Professional With...
I am getting an error " registry editor disabled by administrator"
your win XP 2 infected with virus. Maybe rontokbro@mm. to restore back the regedit. download this file
save to your desktop then
Right-click the UnHookExec.inf file and click install. (This is a small file. It does not display any notice or boxes when you run it).
Hope it's work for you.
Feb 19, 2008 | Microsoft Windows XP Professional With...
S/w question
There are softwares that can be downloaded in order to put password and encryption policies for public folders.
Are these the admin level folders? If they are, then you can simply make your folders private so other people won't be able to see them.
Jan 14, 2008 | Microsoft Windows Server Standard 2003 for...
Hidden files
When you open the window "My Computer" you need to open the "Folder options". under "Folder Options" you have three tabs, you need to click on the "View" tab.
Under "View" tab you have an option as "Hidden files and folders", you may select the option according to your choice over there.
Note : - In win XP the "Folder options" are present under the "Tools" tab, however it might be under the "View" tab in the "my computer" in win 98. I don't have a Win 98 handy to check that. i am sure you would be able to find that out. Once you have the "Folder options" the steps are same as mentioned above.
Hope that resolves your issue. Will wait for tee rating.
Thanks
Sammy
Dec 05, 2007 | Computers & Internet
Microsoft Windows Server Standard 2003 for PC Logo
145 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
