If the clothes going in don't appear wetter than normal, then it's probably lack of airflow.
Check your dryer venting.. especially directly behind the machine. Pull the machine out and disconnect the 4" duct from the back of the machine and visually check for blockage both in the machine and in the duct work. Use a vacuum hose to remove any debris.
You can also start the machine while it's disconnected from the duct, momentarily to check for proper airflow.
Best of success!
Testimonial: "Spot on, its a condenser dryer and the intake filter was blocked. Thank you so much"
How do i put the belt back on
