Dear sir
when I buy it I installed window xp, it work properly, after some time it attacked by virus. then I formate it and again installed win xp and all drivers given in driver cd. Now when I click on shut down or restart, it shows saving yours settings after that show window is shutting down... but never shutdown. so I shut down it by hand from switch. Please help me, I buy it in Nov 2007..
Comments:
Jan 18, 2008
- how can I restore my system in xp setup. pllease give detail.
-   Yes.I have found the same problem in my Acer Laptop -   Jay Hind
May 28, 2008
-   After installing windows xp,my computer does not shut down.I ve to switch off this from power button
-   Guest
May 15, 2008
-   HI Guys...This is susheel from delhi..i have the same problem with this model..i tried installing xp aagin and again but the laptop is behaving vearedly as it started working dead sl;ow even when u install a fresh copy of xp...PLEASE HELP-   sam_3284
Jan 16, 2008
-   hi,
my blue tooth device is not working nd have any solution 4 that?-   Guest
Do not install the webcam driver supplied from acer. If installed, uninstall it. Let xp use its own driver, it will work in explorer.
CN
Was this helpful?
Yes
No
Solution #3
posted on Feb 09, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
HELLOOO THIS IS SANDEEP HAVING THE SAME PROBLEM JUST SOLVED RECENTLY ITS VERY SIMPLE U JUST CALL A TOLL FREE NO GIVEN IN UR VARANTY CARD THEN THEY WILL TELL U HOW TO CLEAR THE PROBLEM WHILE U CALL U SHOULD HAVE AN INTERNET CONNECTION &WINZIP SOFT WARE THEY WILL TELL A SITE & WE HAVE TO DOWN LOAD A SMALL SOFTWARE & AFTER INSTALING THE SOFT WARE U R NOTE BOOK WILL WORK PROPERLY
i have a acer aspire 4710z. This laptop can not open the display but the system unit is working normally. i can not see the display but i can join the external monitor i will see it process. Pls let me know how can i repair it.Pls reply to this email thanks. pyeisone1988@gmail.com
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on Mar 13, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
hello ramavtar..
im also facin the samwe pro..
bt u dnt need to call to the acer toll free no...
just uninstall 1st camera/webcam in acer resourse dvd,n then ull shut down ur laptop properly..
its nt a virus..its sumthin lack of technology in acer..
i gusee the 1st camera is (chicony)...jst do it 4 1nce n ull gve thanxs 2 me...
this is Tanutejas Saraswat,male
, hi, ya its the O/S issue, run in safe mode and restore it to previous working check point, if it has created one, or simply run the XP setup, on the first options screen where it asks u for 3 options, just hit "enter" again later it will ask u if u want to install it on previous OS, there u punch in "R" (repair), this will reinstall the OS keeping ur installed applications and settings intact.. let me know..
Hi, Acer Aspire 5610-4648 PC Notebook main problem is Web Cam Problem, Windows XP Problem etc. For these problem you can visit a link by just Click Here . For any other problem with this Notebook you can Click Here
There in not a problem boss. i also faced the same problem after re-installing xp.
Simply download a windows XP HOTFIX exe from microsoft website of ask for it from acer support centr from delhi.
They will mail u the exe on ur id.
simply install and restart every thing will go fine.
Actually this is due to the drivers of webcam.
Just install Bison Drivers or else let windows have its default drivers.
arunj49@yahoo.com
Was this helpful?
Yes
No
Solution #9
posted on Aug 12, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
when i install acer webcam my laptop do not shut down and after uninstalling it shut downs properly. i also cannot able to connect to tv by svideo function it does not show any thing. pls mail me on vishalt725@yahoo.com
Hello All For Acer shut down problem, I have solution ,You call acer service centre and ask for file ,which run and fix this problem or you mail me on dharmender2801@yahoo.co.in.
when i try to download effects it says that its not valid for winlocker 32 and that it doesn't have...
(More)
when i try to download effects it says that its not valid for winlocker 32 and that it doesn't have a publisher.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
