Question about Reddy Heater-30-55,000 BTU Variable
Wont run I have a small propane reddy heater that will start fine but when i let go of the igniter the flame goes out. They suggest that u hold the igniter in for 15 sec. the heater will not run even if i hold it in for several min.
  • 625 Answers
Two things come to mind here. the high limit shutoff and the millivolt generator. the hi limit cutoff is a thing that looks like a metal pill with two wires coming off it. those two wires connect to the two tabs on the millivolt generator cappillary. its purpose is to keep the millivolt circuit closed. The millivolt generator produces a very small (750 ma) voltage which is in turn connected internally in the gas valve to a small electromagnet. with a flame on the voltage is generated and keeps the pilot valve open. replace either or both devices.
Posted on Jan 14, 2008
6ya staff
SOURCE:
Have an rlp30 reddy heater, have spark and gas but will not light.
wile red button is pushed no flame or turns off when the button is released the flame dies ? if no flame tank is too small or spark isn't in far enough to catch gas . if flame is present with button down then the over heat switch on the in line thermal coupler could b bad u can check the over heat switch with a jumper between the two wires and if it stays lit you got it if it goes out then its the thermal coupler that's bad
Dec 12, 2013 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
3500 propane forced air reddy heater not putting out much heat since I changed bottles
tank is being turned on to fast and the safety valve will close and not let the full pressure go to the burner same with any new tank that has the columbine valve in it pressure sensitive
Mar 25, 2013 | Reddy Heater-30,000 BTU Propane Forced-Air...
I have a 40,000 BTU propane reddy heater. I just refilled the tank and attached it to the heater like I normally do but now when I start it it will run fine then it will flare up and shoot out orange flame...
Did they over fill the tank and you are getting pure liquid to the heater..... Sounds like when you use a propane bottle hand torch and tip it up side down the flame turns orange and goes out. Also the regulator vent may have gotten plugged with dirt or ice. May try and bleed some of the propane pressure off of the top of the tank....... But make sure you have it outside and plenty of ventaltion and no open flame any where...... Propane is lighter than air so it settles down on the ground at the lowest point.....hope this helps..... Or you could take it back to your suppler and get a different tank.
Feb 01, 2011 | Reddy Heater RLP100 Portable Forced Air...
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
The gas does not light
get a new unit dont play with propane it goes bang!!
Oct 31, 2009 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater-30-55,000 BTU Variable Logo
96 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
T bone 1963
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
