Question about Canon PIXMA iP90 InkJet Printer
In tank not installed
I get a message saying that the Color Ink Tank is not installed.
I've changed both the black and color tanks, reset the print head (not replaced), tried seveal different tanks.
It did start working once, but when I powered back up the next day, no luck. Repeated all of the above.
I'd be happy if I could just get the black print to work, but the only option I get is to CANCEL the print job.
  • 3 more comments
  • Joelsails Jan 14, 2008
    Yes I'm using genuine Canon ink.
    Have removed tanks, powered off, on and then off again. Print head doesn't return to center if power is not on, but did go through the steps twice just in case. With new inks.
    I've tried deep cleaning but get the same error message, looking for color cartridge,#16
    Thanks
    And now I've removed the print head and cleaned it again.
    Thanks
    I assume that I'm replying to you both, Soulvistor, and Otacon?
    I went through all the steps outlined, boy that was confusing but the lights blinked as advertised. No change.
    Yes, I did remove the print head, I cleaned the contact points (electrical) also any ink that was hanging around. Re-installed print head, then cartidges.
    Let me try to let the printer cool it's jets for a few hours.
    My biggest problem is that I'm in Manzanillo Mexico, and don't have a clue about how to get a print head down here. UPS will laugh when you ask them, things get held up in customs.
    I'll try to find a local dealer.
    Will keep you posted.
    Thanks to both.
    Question;
    When the print head is removed, there is a small grey (I'll call it sensor) that sticks up through the print head, is there a chance this is not being pushed down by the #16 print cartridge enough for the printer to sense that it is installed? If so, could the print cartridge be built up as a work around? As I mentioned, I'm in Mexico, there are no #16 color cartridges to be had. I'm using both of my last two new ones.
    Is there a way to just print black?
    Thanks
    President:
  • 1,944 Answers
Did you try cleaning the contacts on the printer head?
Posted on Jan 14, 2008
  • 1 more comment
  • Damen Wong
    Damen Wong Jan 14, 2008
    Also, try disconnecting from the power and computer for a few hours, then reconnect and see if it helped.
  • Damen Wong
    Try this if yo would like to try a reset
    1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
    4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
    5) Press the Power button. The LED lights in green, and the
    selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
    6) Power off then back on and test.
  • Damen Wong
    Change print settings to black/monochrome/greyscale only and then the printer will only print in black (it also shouldn't look for a color cartridge).
  • Canon Master
  • 1,113 Answers
Are you using genuine Canon inks? Try remove inks, power off, power on, let start up without ink, power off, installed inks
  • 8 more comments
  • Soulvisitor
    Soulvisitor Jan 14, 2008
    I know you said you have removed head and cleaned but I'm wondering if you cleaning the ink head instead of the contacts
    Please try to clean the electrical contacts on the machine carriage that connect to the head's electrical contacts(with head removed)
  • Soulvisitor
    If you have cleaned contacts are using gen inks, have tried another set of inks then it has to be the head
    Part info/price/purchase
  • Soulvisitor
    Yes two are us are trying to help, I now beleive it is the head as per my last post.
    Cheers
  • Soulvisitor
    I've just been reading a post about simular print Ip70 and people have reported that unistalling and then reinstalling the software has fixed the issue, might be worth a shot, con see the logic myself but ...?
  • Soulvisitor
    just tape it down, worth a shot.
  • Soulvisitor
    with the power on and colour out, does pushing sensor remove the error "colour ink not installed"?
  • Soulvisitor
    no tank is indicated by orange blink 4 time on printer
  • Soulvisitor
    please confirm you are using BCI-16 Cl not BCI-15 Cl colour tank
  • Soulvisitor
    From the service manual.....Japanesse english!
    BCI-16 Color is NOT compatible with BCI-15 Color.
    Although BCI-16 Color and BCI-15 Color are mechanically and electrically same, the color
    conversion process of the printer driver is different.
    Use of BCI-15 Color on the PIXMA iP90 /PIXUS iP90 (or BCI-16 Color on the i80 / PIXUS 80i) is not allowed to avoid undesirable effects on printouts.
    However, use of BCI-15 Color on the PIXMA iP90 / PIXUS iP90 (or BCI-16 Color on the i80 / PIXUS 80i) does not cause any mechanical damages to the printer.
  • Soulvisitor
    No just black option is available, try the switch, if it is indicated by computer status monitor try reinstall but if you getting no tank error on printer cant see that working, try a new cart possible head. Let us know how you get on
    Cheers
    S.
Hi, My Canon MP210 printer is displaying E3 code. The colour light and alarm lights are illuminated constantly and black one is flashing. When opening the "lid", the cartridges do not align to...
I have workaround for the empty tank issue:
- buy or borrow another not empty tank
- place it in
- start the printer
- it recognises the "new" tank
- turn off the printer
- put back the old, empty, but refilled tank
- turn on the printer
- print something
- it will pop up a dialogue window saying
"The ink level of the black/color tank cannot be
determined. The ink level determining function will be
disabled for the black/color tank.
If you want to continue printing without this function
press the Start button on the printer."
- Press the Start button on the printer and ignore the
button 'Cancel Printing' appearing on the dialogue window.
- The dialog window disappears.
You can print your refilled tank as many times you want from this time.
When you go to 'Printers /Canon /Properties /Maintenance / Printer Status / Ink Information' it says that the ink level measuring function has been disabled for: black [40] / color[41]. You can ignore this this message, the printer will work perfectly without this stupid function.
Mar 18, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Cannot print
Change the cartridge ...
but, in case E3
- place it in
- start the printer
- print something
Mar 18, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Color tank isn't installed --- but it is!
Make sure that all tickers are off from the tank and clean the housing good and run self clean first and reset the printer
Nov 07, 2009 | Canon PIXMA iP90 Mobile Printer
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
"More Than One Ink Tank Of The Following Color Is Installed"
Try using clean cotton cloth, like from an old t-shirt, and clean the contacts on both the ink cartridge and the seat inside the slot where the ink cart goes. If you clean them both, for each cart color, you might fix this problem.
Be sure that the power is off when you do this first!
Jun 21, 2009 | Canon Pixma MP800 All-In-One InkJet...
How do you remove the ink cartridges from Canon MP890?
  1. If replacing both ink tanks, remove and replace each one individually.
  2. Make sure the device is powered on.
  3. Lift the scan unit until it locks into place. When the machine is ON and the scan unit is lifted, the paper output tray automatically opens.
  4. Open the inner cover.
  5. Hold the tab and pull it forward to release the ink tank.
  6. Lift out the ink tank.
  7. Remove the new ink tank from its packaging.
  8. Hold the ink tank and remove the protective cap.
  9. Insert the ink tank into the empty slot on the print head.
  10. If you need to replace the other ink tank, repeat steps 4 to 8.
  11. Close the inner cover.
  12. Return the scan unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  13. Press [<] to select <YES>.
  14. The LCD displays a message asking if you replaced the black ink tank.
  15. If you replaced the black ink tank, press [<]. If you did not, press [>].
  16. The LCD displays a message asking if you replaced the color ink tank.
  17. If you replaced the color ink tank, press [<]. If you did not, press [>].
  18. The ink counter is now reset.
  19. If additional ink tanks need to be replaced, replace them now.
Jan 22, 2009 | Office Equipment & Supplies
Canon IP5200 printer - "duplicate ink tanks"
Hi i have Ip 5200 but the pawer lamp and yelow lamp are blink
Mar 26, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Canon multifunction printer
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
Feb 18, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA iP90 InkJet Printer Logo
229 people viewed this question
old marine
old marine
