Question about Dell 1600n All-In-One Laser Printer
"Warming up Please wait" error
I am working on a Dell 1600n laser. It restarts itself several times when powering on and eventualy gets stuck on the message "Warming up Please wait". Some times it won't do any start up functions and displays a solid shaded line on the display. If I disconnect the scanner wires from the system control board it knows enough to display a "locked scanner message". I am thinking the Power supply board needs replacing? Any diagnostic help and/or parts locating help would be great. Thanks in advance.
  • lianemom Feb 06, 2008
    I have the same problem, but it sounds like it is feeding paper and the roller where the paper comes out keeps rolling.
    Scholar:
  • 105 Answers
Suspect the toner heating element (fuser) may be malfunctioning. Dell may be able to walk you through a "hard reset" that involves opening the front door, turning on an off the printer with certain buttons held down, etc.
Posted on Mar 27, 2008
Won't go to menu
Had a similar problem on a HP MFC3330
Fixed it with the following video aid:
"how to fix the scanner bulb warming up error hp 3330 or repair 3380 scanner bulb warm up problem - YouTube"
http://youtu.be/lqG_nmi3vC4
Hope it helps...
Jul 27, 2014 | Dell 1600n All-In-One Laser Printer
How do you power cycle a dell 1600n
All power cycleing is powering down the printer, waiting 10 seconds and powering it back on.
Aug 03, 2010 | Dell 1600n All-In-One Laser Printer
Dell 1600n error - What does "open heat error" mean
1. Please check the thermostat in the fixing unit.
2. It may open due to over heat. replace it. clean thermister.if spoiled replace it also.
Jul 15, 2010 | Dell 1600n All-In-One Laser Printer
How do I repair an "open heat error"?
I'm sure it's not the answer you're looking for but the "Open Heat" error is related to the printer's fuser, switch mode power supply or temperature control thermistor. More than likely it's the fuser which needs replacing and you'd need to contact Dell for a replacement. If you google for "1600n fuser" you'll also come up with several retailers with fusers in the $80 range as opposed to Dell's $140+.
Jan 21, 2010 | Dell 1600n All-In-One Laser Printer
Dell 1600n I replaced the toner and can't get the "replace toner"
After you clear out the print que (double click on the printer icon on your desktop), power down the printer, wait 20 seconds and power it back up. The "replace toner" should clear after the sensor detects toner in the hopper AND the new chip in the toner cartridge registers with the "brain" of the printer. Hope that helps!
Aug 12, 2009 | Dell 1600n All-In-One Laser Printer
Open heat error
Open heat error is a fuser error. If you have plenty of clearance around the printer and you are still getting this error, it is the fuser.
Mar 24, 2009 | Dell 1600n All-In-One Laser Printer
Fax tries to receive randomly during phone calls
Disconnect , Uninstall then Reinstall the software.
Feb 05, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n only receives 1 page of fax.
turn off ECM (error correction).
then if problem persists, slow down the fax speed to 9600 bps.
this problem always occurs with a digital or VOIP line.
Jan 14, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600N warming up message
Hi Unplug the printer power cable from the wall and disconnect it from the printer as well. Turn the printer power switch on for 15 seconds. This will reset the printer. Turn the printer power switch off and plug the cable back in on both ends. Then turn power on. The Document Jam error should be eliminated.
Please keep in mind you must check for any small pieces of paper or look for a real paper jam prior to completing the steps above.
I hope that helps.
Sep 16, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600N Multifunction printer problem.
Fuser issues - if problem is reoccuring then you are looking at more expense, are all vents free of obstructions (folders leaning on machine sides/rear) is machine being flogged, is power supply consistent, maybe even fuser bought was faulty, many options, try doing a warranty claim on fuser or replace again, even better get another printer, welcome to our throw away world!
Oct 31, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
1,083 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
