Question about Onkyo TX-SR503 Receiver
Volume is changing/decreasing
We used to set the volume at 23, now we're up in the mid 40's in order to get the same level of volume. This is happening when used on a HD TV. Any suggestions to correct this would be appreciated. Thank you!
Well, that information is slightly undescriptive and unnecessarily vague, but I think I can suggest a few things.
If the problem only occurs when watching your HDTV, I am assuming you are using the Audio Out on your TV to pipe sound down to your Onkyo receiver. If this is the case, the TV volume may be turned down lower by mistake and you have to turn up the Onkyo's volume to correct for the difference.
Another possibility is that some other variable has changed i.e. source material, programming, TV firmware update. What did you change to get this to happen? Is it reproducible? Can you use other source material (DVD, VCR, or DAP (mp3 player) and use it at the same volume levels as before? I tend to think that your problem is with the HDTV, not the Onkyo. User error is the most common type.
Posted on Jan 25, 2008
Adjust bunn coffee maker water level
To adjust the brew volume/batch size you will need to access the main circuit board behind the front panel. Isolate the machine before removing panels.
NOTE: Check that the brewer is connected to water supply, the tank is properly filled and a funnel and server or decanters are in place prior to setting or modifying batch sizes.
  1. Modifying batch sizes: To modify a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. If the brewer has a batch selector switch, position it to the size to be changed. To increase a batch size: Press and hold the START or BREW switch until three clicks are heard. Release the switch (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory) and press it again one or more times. Each time the switch is pressed, 2 secs are added to the brew time period. Allow the brew cycle to finish in order to verify that the desired volume has been achieved. To decrease a batch size: Press and release the START or BREW switch once for every 2 sec interval to be removed from the total brew time period; then immediately press and hold down the START or BREW switch until three clicks are heard. Release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). Allow the brew cycle to finish in order to verify that the desired volume has been achieved.
  2. Setting batch sizes: To set a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. Press and hold the START or BREW switch until three clicks are heard (this will take approx. 10 secs) and then release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). View the level of the liquid being dispensed. When the desired level is reached, turn the ON/OFF switch to "OFF". The brewer remembers this volume and will continue to brew batches of this size until the volume setting procedure is repeated. Empty server(s), turn selector switch to positions that have yet to be set and repeat batch setting procedure until all batch sizes are set.
    NOTE: When brewing coffee, batch volumes will decrease due to absorption by the coffee grounds.
  3. Setting programming disable feature: If it becomes necessary to prevent anyone from changing brew times once
    programmed, you can set the SET/LOCK switch to the "LOCK" position. This will prevent any programming to be done.
    NOTE: If the clicks cannot be heard, lightly grip the incoming water line to feel when the valve cycles on and off.
Jun 22, 2014 | Bunn CWTF15-TC
My TD-26 turns on and it has high level volume. It"s don"t like me. How change it when is it turns on and has medium level volume
the volume has the issue, I suggest you try to clean it up with the right liquid, or try to see if it is stuck!
Jun 04, 2014 | Santai TD-V26 Portable Mini Digital...
How do I set volume ?
Which volume do you want to change?? call volume or ringtone volume??
For call volume, you can change when making a call.just use the side buttons to increase or decrease the volume.
For the ringtone, you can do that in settings. thanks.
Jul 24, 2011 | Nokia 2610 Cellular Phone
My 8350 was working fine now i cannot hear the phone ring and cannot hear text alerts
make sure the phone isn't on silent by checking the volume level.
Jul 24, 2011 | Blackberry Curve 8350i
HOW DO I TURN UP THE VOLUME
Users will continually need to quickly change the volume on a TOMTOM units, depending on the loudness of traffic noise, the radio or conversations. Although there are no external volume controls, the volume on the ONE can be easily accessed on screen by touching the bottom left corner of the map display. Once the volume controller appears you just slide your finger to increase or decrease volume. We found the audio levels a little softer on this unit and had to set the volume to around 60% or 70% in order to clearly hear it.
Please rate my help++++Thanks for using Fixya
Dec 12, 2009 | Tomtom One XL GPS Receiver
The volume is all the way up, but its as if the volume is about halfway up. Also, there is static in the background
If you are using a DTV box to receive digital TV signals use it to control the volume. Set it to a mid range level and adjust the TV volume to a satisfactory level. Then use the DTV control to raise or lower the volume as needed.
Oct 29, 2009 | Televison & Video
Volume control on tom tom 830
With the tt on and displaying the map, tap the bottom left side. At the bottom a slider bar will appear. Use your finger to adjust the volumn to your desired level. Another way is to tap the map screen, then tap change preferances, tap the arrow until you come to volumn preferances and change the volume setting there.
Apr 30, 2009 | LG LN735 GPS
Cit200
Adjusting the volume of the caller's voice
You can increase or decrease the volume of a caller's voice during a call. There are 5 volume levels for selection.
To adjust the volume, during a call: While the phone is off hook (i.e. dial tone can be heard), press Up or Down.
The display shows the current volume level. Press Up or Down again to adjust the volume.
Still can't find the most comfortable level?
Besides adjusting the volume on the handset, you might also need to adjust the volume on your PC in order to set the speaker to the most comfortable
volume.
To set your handset's ringing melodies and volume:
1. Press MENU.
2. Press Up or Down to select SOUNDS. Press OK.
3. Press Up or Down to select HANDSET. Press OK.
4. Press Left or Right to change the volume level. Press Down.
5. Press Left or Right to select the external melody. Press Down.
6. Press Left or Right to select the internal melody. Press OK to confirm when finished.
Nov 01, 2008 | Linksys CIT200 IP Wireless Phone
MY POWER MAX 5.8 SAYS THAT MY VOLUME IS OFF ON ONE HAND SET--HOW DO I TURN IT ON? THANKS EILEEN CARTER beileenc@bellsouth.net
There are different ways to adjust the ringer and speaker volume on your handset. Please see your owners manual for model specific instructions.
On most single handset units:
Ringer volume: Press the volume up or down arrow rapidly to change the ringer volume.
Speaker volume: When talking on the handset press the volume up and down arrow to increase or decrease the volume.
On other models:
Ringer volume
In standby mode, press the volume up key or volume
down key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Earpiece and Speaker Volume
You can select from among of six volume levels on the
handset, and ten levels on the base. Pressing the
volume up key or volume down key on the handset or
base during a call will change the earpiece or speaker
volume. This setting will remain in effect after the
telephone call has ended.
If you press the volume up key when the earpiece is at
the maximum volume level, an error tone sounds.
The error tone also sounds if you press the volume down key at the lowest volume.
Sergio
Mar 13, 2008 | Lands Phones
Sound Level Changes Constantly
Make sure digital sound control is not set to optimal
Make sure incredible surround is off
Press optimal sound mix until it says "OSM Off"
Double-check the speaker connections
May 07, 2007 | Philips FWC399 CD Shelf System
Onkyo TX-SR503 Receiver Logo
140 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
