Question about Kenmore Elite HE4 Electric Dryer
Manuals Hi, My husband used to live in canada and bought a side by side kenmore ref (970-C566436) 5A 110V, a kenmore dryer model: 110.c82832100 and a kenmore washer model: 42832 200.He brought all of them to iran but lost all the manuals.Also we have 220v electrical power in iran and have to use transformer to reduce the voltage to 110v.But still can not operate the dryer.i am sure we have problem in wire connection.so you are kindly requested to help me finding all the manuals.
  • 770 Answers
I thinkl you can order the manuals from www.sears.com under the parts tab enter your model # also if it is an electric dry it is 220v with a neutral leg check with the local electrian to see if the power there is phased..Hope this helps
PS::The washer and the refrig will work on the tranformers
Posted on Jan 22, 2008
Sears/Kenmore (Canada) Model# 970-681821 . Anyone know manufacture date and if there is an Owners Manual available?
Hello Anna Dee;
My name is Peter. I am a retired field service refrigeration technician.
What a run around! Look on the inside of the fresh food section of your refrigerator. There is a label on the wall near the top. The date of manufacturer is on the label. Also the correct model number. Send me the model number.
What is the problem? Refrigerators are not designed to operate in a garage. If you purchase a new unit and it was under warrantee, the warrantee would be voided if it were operating in a garage.
I was a Sears field service technician. I have never heard of a garage heater kit.
Sorry, you got the run around. The customer service people are under trained, and the telephone technical personal have never spent a day in the field.
I live in Glen Burnie, Md. Call me 443-306-1362
Dec 08, 2014 | Kenmore Refrigerators
How do I stop my kenmore dryer, model 970-c87172, from beeping? Drying, cool down, wrinkle rid and clean lint filter lights flash 3 times. Start light doesn't flash at all. It does this even
Hi Brenda
First off It seems that you model is not correct. Kenmore model numbers start with 3 number followed by a . and then some more numbers. Most Kenmore laundry numbers start with 110.xxxxxxxx. The number you have looks like a serial number which is no help.
Oct 19, 2014 | Kenmore Dryers
Dryer drum gap, tear clothes
Here ya go...
http://www.appliancepartspros.com/search.aspx?model=970-c98802
hope this helps. missing glides surley are the problem. Been there had that.
Merry Christmas
Dec 25, 2017 | Kenmore Washing Machines
Can I plug GE dryer GTDP250EMWW directly to 220v? the manual says that the power rating of this model is 110/220v.
If the dryer is electric and bought in the United States then you can plug it in. The 110/220 power rating basically means that some parts if the dryer use 110v. All 220v is is 2 110v independent circuits sharing the same common ground.
Sep 06, 2012 | GE Dryers
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
I have a kenmore 99701 series combo w/d. they tell me they are all 110. told them 220. neeed to know for sure as cord was taken off and screws missing and loose. don't know for sure and if grounding is...
Well for sure the washer is going to be 110v. Only electric dryers are 220v!. If your dryer doesnt have a gas connection on it then it is a electric 220v dryer. If it has gas connection then it is 110v gas dryer. there is no such thing as a 220v gas dryer!!!.
Mar 25, 2010 | Kenmore Washing Machines
Is kenmore 98702 220?? or 110???
if it has a small 3 prong plug then it's 110v for the washer but the dryer should be factory 220 volt however many were sold wired too! 110 volt! just look at the plug small plug 110v large 3 prong! 220v
Jan 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Bought LG DLE2532W Dryer it in Canada, need to use it in Europe
For to use it with a 220/ 240vac system,you will need to convert 110vac 60hz/to240vac 50 hertz single phase therfore your transformer should have this rating,also it has to be able to handle up to 3kw or 3000watts in power, maybe just as cheap buying a new drier....
Nov 28, 2009 | LG DLE2532W Electric Dryer
The heating element won't get hot? Each wire to the element is getting 110v, but when checked together i am not getting 220v to the element?
Hi: 220 volts to a dryer are two 110 volts combined. Two separate wires. Did you check the heating element? See if it's broken. If so replace it. FIRST, Another thing to check is your circuit breaker. If it has only one side blown you will show 110 volts but that's all the dryer will get and dry slowly. The washer will still work as it's only 110v. I hopes this helps, Jeff
Jun 07, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore Elite HE4 Electric Dryer Logo
590 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
